RentalSkates 0 Posted February 25, 2019 Posted February 25, 2019 Hello, I believe that ever since my Emby server updated to 4.0+, the LG app in horizontal layout has been broken. My library is a mixed content folder with two folders in it: TV Shows and Movies. When I view it on the LG tv it shows my home screen with these two folders in it. There's no "Next Up", "Continue Watching" etc. It just looks like this: https://i.imgur.com/m1ZOR1U.jpg That is also how it looks from the http://tv.emby.media/ page. I found an image by someone else on these forums of what the layout used to look like: https://i.imgur.com/037m4Zo.png I'm trying to get back to something like this. When I switch the layout to vertical, I get some of the features back "Next Up" etc. but I don't seem to get the Movie and TV categories. Any help would be much appreciated!
Solution Luke 42234 Posted February 25, 2019 Solution Posted February 25, 2019 Hi, for mixed content it is currently just a folder view. To get the special layouts for movies and TV you'd have to separate it into distinct libraries for each type. You can also try the vertical home screen. Please let us know if this helps. Thanks. 1
RentalSkates 0 Posted February 25, 2019 Author Posted February 25, 2019 Perfect, it works as desired now Thank you very much.
