nevolex 4 Posted February 25, 2019 Posted February 25, 2019 (edited) Hi guys, I got my Emby installed and it works just fine, however I cannot access it by clicking on the icon in the QTS, it basically opens up a page with address https://192.168.1.2:8920/ and the port which is not in use. I understand there is something with a certificate. however it is rather a strange behavior, for example I am not using the port 8920 for ssl it has been changed to 9001 but still every time I click on it, emby forwards me to this page with the default port https://192.168.1.2:8920/. Is there a way to configure Emby to open up a default page http://192.168.1.2:9000 and not https://192.168.1.2:8920/ so I don't have to every time change https to http and port from 8920 to 9000 Kind regards Edited February 25, 2019 by nevolex 1
Luke 42241 Posted February 25, 2019 Posted February 25, 2019 Hi, outside of configuring SSL, I don't think there's a way. You may want to just setup a browser bookmark with the http url. 1
nevolex 4 Posted February 25, 2019 Author Posted February 25, 2019 (edited) Hi Luke, thank you for the quick answer, I just had another question, is there a way Emby can be opened with a different IP address, for example 192.168.1.25 and not 192.168.1.2. I have a local simple dns server running in the network to resolve a few local ip addresses, for example 192.168.1.2 can actually be opened as qnap.local however as emby runs from the same ip but the different port, there is no way i can just map a new "domain name" to it. Thank you Edited February 25, 2019 by nevolex
OneCD 10 Posted February 25, 2019 Posted February 25, 2019 (edited) Hi guys, I got my Emby installed and it works just fine, however I cannot access it by clicking on the icon in the QTS, it basically opens up a page with address https://192.168.1.2:8920/ and the port which is not in use. You''ll need to update the App Center icon information. Edit [/etc/config/qpkg.conf], find the Emby configuration block, and ensure your web UI port number is adjusted. Then reload the App Center and try the QPKG icon again. Edited February 25, 2019 by OneCD 1
nevolex 4 Posted February 25, 2019 Author Posted February 25, 2019 Hi. OneCD I tried to open this file in VIM but it seems to be empty? /etc/config/qpkg.conf You''ll need to update the App Center icon information. Edit [/etc/config/qpkg.conf], find the Emby configuration block, and ensure your web UI port number is adjusted. Then reload the App Center and try the QPKG icon again.
OneCD 10 Posted February 25, 2019 Posted February 25, 2019 (edited) Can you please run this command and post the result shown in your terminal session? qfile=/etc/config/qpkg.conf; cat $qfile; ll $qfile Edited February 25, 2019 by OneCD 1
nevolex 4 Posted February 26, 2019 Author Posted February 26, 2019 (edited) Can you please run this command and post the result shown in your terminal session? qfile=/etc/config/qpkg.conf; cat $qfile; ll $qfile Thank you OneCD, please find the log attached log.txt Edited February 26, 2019 by nevolex
OneCD 10 Posted February 26, 2019 Posted February 26, 2019 Hmm... the file definitely exists then. When you selected the filename for editing via vim, did you use the correct character-case? 1
OneCD 10 Posted February 26, 2019 Posted February 26, 2019 An alternative to direct file editing is to use QTS's own config file modification utility. Example: to change the Emby SSL port to be 12345, use: setcfg EmbyServer Web_SSL_Port 12345 -f /etc/config/qpkg.conf 1
nevolex 4 Posted February 26, 2019 Author Posted February 26, 2019 Thanks a lot OneCD, it did work just fine on the 2nd attempt, not sure what file I opened in VIm first time, , I have adjusted the port. However by default I still cannot open the page as http, it still tries to open it as https, which i don't have a certificate for so the connection is rejected. I couldn't find the line in the qpkg.conf responsible for it or did I miss it? Thanks again
Solution OneCD 10 Posted February 26, 2019 Solution Posted February 26, 2019 However by default I still cannot open the page as http, it still tries to open it as https, which i don't have a certificate for so the connection is rejected. I couldn't find the line in the qpkg.conf responsible for it or did I miss it? Are you logged into your QTS via HTTPS? Or HTTP? I'm not sure but I think if you log into QTS via HTTPS, it will then try and open QPKG app pages in HTTPS too. Maybe try commenting-out that line in qpkg.conf with a hash character: #Web_SSL_Port = 8920 Then reload App Center. This will leave the value of 'Web_Port' as a valid UI port. Another idea is to maybe create an exception in your web-browser for that page? 1
nevolex 4 Posted February 26, 2019 Author Posted February 26, 2019 OneCD, it did the trick, thanks a lot!
OneCD 10 Posted February 26, 2019 Posted February 26, 2019 Awesome! Which part worked? Did you comment the Web_SSL_Port line or did you create a browser site exception?
nevolex 4 Posted February 26, 2019 Author Posted February 26, 2019 Awesome! Which part worked? Did you comment the Web_SSL_Port line or did you create a browser site exception? Commenting out #Web_SSL_Port = 8920, which is basically now forcing emby to use http over https and also connecting the right port Web_Port = 9000 (i changed it from the default one) that works too. I edited the conf directly with VIM. Did not have to add any exception to browser which makes this a good unified solution, thanks again. Much appreciate your help! 1
Luke 42241 Posted February 26, 2019 Posted February 26, 2019 How difficult was all of this? Is it something we can/should automate in the package?
OneCD 10 Posted February 26, 2019 Posted February 26, 2019 (edited) Commenting out #Web_SSL_Port = 8920, which is basically now forcing emby to use http over https and also connecting the right port Web_Port = 9000 (i changed it from the default one) that works too. I edited the conf directly with VIM. Great! Good work. @@Luke, I'm not sure. Changing QPKG port numbers is always a pain as QTS has no mechanism to read the new port number assigned in the app. It's like creating a Windows desktop shortcut, then moving the target. Windows has no idea where the target went. A solution I use in some of my own packages is to include an automated check for that app's web UI port number, then write that into the QTS App Center config file so the user will have a valid start icon. But, it only updates when the package is started. This is a snippet: if [[ $(/sbin/getcfg misc enable_https -d 0 -f "$SETTINGS_PATHFILE") = 1 ]]; then ui_port=$(/sbin/getcfg misc https_port -d 0 -f "$SETTINGS_PATHFILE") msg+='HTTPS port: ' else ui_port=$(/sbin/getcfg misc port -d 0 -f "$SETTINGS_PATHFILE") msg+='HTTP port: ' fi if [[ $ui_port -gt 0 ]]; then /sbin/setcfg $QPKG_NAME Web_Port $ui_port -f "$QPKG_CONF_PATHFILE" msg+=$ui_port else msg='! no web service port found' fi Edited February 26, 2019 by OneCD
nevolex 4 Posted February 26, 2019 Author Posted February 26, 2019 How difficult was all of this? Is it something we can/should automate in the package? It was really easy, basically I had to do was editing the file in /etc/config/qpkg.conf I changed 2 lines: Web_Port = xxxx - custom port I set up earlier in emby web interface for http connection so it reflects the changes in the web link (emby icon) in QTS And commented # like that #Web_SSL_Port = 8920to bypass https and now even thought I connect to qts over https, emby runs perfectly fine with http. It just says that https is not available would you like to connect any way. Cheers
Moogle Stiltzkin 1 Posted May 19, 2019 Posted May 19, 2019 i posted in the other thread before i noticed this one https://emby.media/community/index.php?/topic/46884-cannot-connect-to-emby-server/page-2 but essential the default emby icon link in appcenter tries to open on the https port url which doesn't work by default (at least for me anyway). the only way for me to access it to NOT use the clickable link in appcenter for emby.... instead i have to type in browser url http://192.168.0.xxxx:8096/mediabrowser which does work. yes im logged into QTS via https. anyway it weirds how emby clickable url goes to a broken url. maybe you should make this a setting in emby to use https or not. cause it's just defaulting to https which doesn't work. needs a solution for https to work ideally if possible. right now all i'm using emby for is local access, but at some point i'd like to use emby for remote access later
Luke 42241 Posted May 19, 2019 Posted May 19, 2019 Hi, unfortunately it is a QNAP button and it wants to use https but in order for that to work you need to set it up in the advanced server section of emby server. So it's a little bit of a chicken and egg scenario. 1
