denz 501 Posted February 24, 2019 Posted February 24, 2019 When you delete an recorded episode in episode view it doesn't refresh the view i can still see the deleted episode in the list and when you go back i can see the episode number change and when i go into it it displays oops something went wrong document not found on stack. It still gets in the episode view and I able to watch a different recorded episode.
corey 317 Posted February 24, 2019 Posted February 24, 2019 I don’t quite follow what you’re describing and for me to take a look I need a bit more detail. Would you please provide a step by step description of what you’re doing (each screen and what you’re doing on that screen) so I can help you out? Thanks!
denz 501 Posted February 24, 2019 Author Posted February 24, 2019 (edited) No problems I will try again i took screenshots from emby ios client. so step 1 you go to live tv recordings and select a series in this example I chose gogglebox and then go into a series season in this example I selected season unknown i then watched the first episode on the list after watching it I selected delete and it brought me back to the episode list but the deleted episode was still there then i clicked back and the number of episodes in the season reduced so in the example it will go from 12 to 11 and if i click season it displayed an error. Hopefully this helps Edited February 24, 2019 by denz
denz 501 Posted March 24, 2019 Author Posted March 24, 2019 Have the devs able to replicate this issue as I still keep getting that error no document found in stack.
Luke 42241 Posted March 27, 2019 Posted March 27, 2019 Did you perform the delete from within the apple tv app?
denz 501 Posted March 28, 2019 Author Posted March 28, 2019 Yes in apple tv where I get this error not found in stack. I will try over the weekend to delete recordings in android tv and roku to see do they have this error.
denz 501 Posted March 28, 2019 Author Posted March 28, 2019 Now I can see why it is hard to replicate. Watched two recording from episode list and deleted them the episode list doesn't get updated as you delete episode I go great error has been fixed then I went to watch a different series and as I pressed it I got error no document found in stack. Does apple tv have logs to help solve this error ?
ebr 16335 Posted March 28, 2019 Posted March 28, 2019 Unfortunately, not easily accessible. I'm afraid I didn't completely follow this though: and deleted them the episode list doesn't get updated as you delete episode I go great error has been fixed Can you list the exact steps you are going through?
denz 501 Posted March 29, 2019 Author Posted March 29, 2019 This is the web client equivalent episode list that doesn't get updated on Apple Tv. If you decide to watch Minister D and delete it you are taken back to the episode list and it will still have Minister D it doesn't refresh the list on deletion.
denz 501 Posted March 30, 2019 Author Posted March 30, 2019 I have attached photos so you can see exactly what is happening it doesn’t refresh the episode list and if you click on the recording that you just deleted all you get is a spinning circle
denz 501 Posted March 30, 2019 Author Posted March 30, 2019 I have been able to reproduce it now every single time if The episode list gets refreshed that will fix the error as i can reproduce the error every single time click on the episode that you deleted go back and click on the season and that error appears.
