Carlo 4561 Posted September 20, 2020 Posted September 20, 2020 Because in the apps you can select a default subtitle language. So we need to make sure that the logic in the back uses the 2 and 3 letter abbreviations correctly.
daedalus 434 Posted September 20, 2020 Posted September 20, 2020 (edited) 6 hours ago, cayars said: Because in the apps you can select a default subtitle language. So we need to make sure that the logic in the back uses the 2 and 3 letter abbreviations correctly. takes just a couple of secs to check that up by yourself, all 3 language variant correctly get identified ger.forced.srt || de.forced.srt || german.forced.srt omiting any language tag correctly defaults to undefiend full language written only works in english, should also be stated somewhere, but thats a general problem, cause you don't use localized language names anywhere, use the english ones, cluttery, buy hey its emby and that that happens, if you dont know how this all have to look like: commentary.default.srt, grabbl83.forced.srt <-- completely wrong language, that much for "you can write anything you want" || deutsch.forced.srt (localized version of "german") <-- seems correct for german speaking ones, but no app will pick the "wrong" language so time to finally update the wiki im always staggered how much background check up basic things need here Edited September 20, 2020 by daedalus 1
Carlo 4561 Posted September 20, 2020 Posted September 20, 2020 Takes more than a few seconds to try every language combination. You never know if code is added for a few key languages vs handling ISO abbreviations correctly across the board. But I suppose using the same logic trying a couple combinations of some off the wall hardly ever used language would tell the tail as well.
daedalus 434 Posted September 20, 2020 Posted September 20, 2020 24 minutes ago, cayars said: You never know if code is added for a few key languages vs handling ISO abbreviations correctly across the board. the first one would be unspeakable dumb in a media server environment 1
