jusx 0 Posted February 21, 2019 Posted February 21, 2019 I have a emby server on ubuntu mate 18.10; some days ago I have watched the some movies on certain folder doesn't load to emby metadata. I refreshed uncountable times with the option "Refresh Metadata" and nothing happends. For more info I attached the last log info
Luke 42217 Posted February 21, 2019 Posted February 21, 2019 Hi there, can you please go over an example? thanks.
jusx 0 Posted February 22, 2019 Author Posted February 22, 2019 (edited) Ok, in this log(https://pastebin.com/ygty1XgM) I was created a library called movies 2018 referenced from their respective path, but when I'm waiting on web server none movies are loaded. Even the system write on log as: "Watching Directory " (line # 720), but I've been wating for a long time but this section still empty on my emby server, as you can see bellow... PD: sorry the first log on this topic was another old log.. Edited February 22, 2019 by jusx
Luke 42217 Posted February 23, 2019 Posted February 23, 2019 @@jusx, did you add any folders to the library in Emby library setup?
jusx 0 Posted February 23, 2019 Author Posted February 23, 2019 (edited) Yup, is in the log file line 720, but if you trying to tell any other folder? nop yet Edited February 23, 2019 by jusx
Luke 42217 Posted February 23, 2019 Posted February 23, 2019 Can you show a screenshot of emby library setup? have you run a full library scan since adding it? thanks.
jusx 0 Posted February 24, 2019 Author Posted February 24, 2019 sure, both emby setting library and folder properties Folder properties
Luke 42217 Posted February 26, 2019 Posted February 26, 2019 Have you created any other libraries in Emby library setup?
dragonkeyper 1 Posted February 27, 2019 Posted February 27, 2019 Can you try creating a new directory and copy a few of your movies to the new directory and then create a Library using it as the folder?I've been having the same issue and for some reason this was the only thing i could get to work. If it works for you also it may provide the Devs some insight into whats happening. 1
jusx 0 Posted February 27, 2019 Author Posted February 27, 2019 ok, I'll do it, post the results Can you try creating a new directory and copy a few of your movies to the new directory and then create a Library using it as the folder?I've been having the same issue and for some reason this was the only thing i could get to work. If it works for you also it may provide the Devs some insight into whats happening.
jusx 0 Posted February 27, 2019 Author Posted February 27, 2019 Have you created any other libraries in Emby library setup? Sure... look
Happy2Play 9806 Posted February 27, 2019 Posted February 27, 2019 Can you post another server log. Is this 2018 folder covered in any other library folder already added? What folders do you have assigned to Movies on Disk 1 (1TB)?
jusx 0 Posted February 27, 2019 Author Posted February 27, 2019 (edited) Can you try creating a new directory and copy a few of your movies to the new directory and then create a Library using it as the folder? I've been having the same issue and for some reason this was the only thing i could get to work. If it works for you also it may provide the Devs some insight into whats happening. you have all the reason dragonkeyper, emby server have been sync the folder as you see bellow but even with that result, I need to know what was happened with emby Edited February 27, 2019 by jusx
dragonkeyper 1 Posted February 27, 2019 Posted February 27, 2019 On the surface this appears to be the same issue that is happening with my library, either we both are making the same mistake (great minds think a like) or we have something in our library that is adversely affecting the scan of our movie folder. Hopefully someone with more experience can chime in,
Luke 42217 Posted February 27, 2019 Posted February 27, 2019 What folders are in Documentales, Movies and Movies2018? Can you show all of those? thanks.
jusx 0 Posted March 4, 2019 Author Posted March 4, 2019 What folders are in Documentales, Movies and Movies2018? Can you show all of those? thanks. here..
Happy2Play 9806 Posted March 5, 2019 Posted March 5, 2019 (edited) To my question in post 14. What folders are attached to "Movies on Disk 1 (1TB)" library? Looking at the screenshot in post 13 for "Movies on Disk 1 (1TB)" shows movies from the "2018" folder (The Titan and Pacific Rim:Uprising). You can not have two libraries that cover that same content. So I bet you can use Search and find every movie in that folder. Edited March 5, 2019 by Happy2Play
