DarWun 357 Posted February 19, 2019 Posted February 19, 2019 (edited) App Versions:- Emby v4.1.0.8 beta (Synology NAS .NET Core)- Kodi Companion v2.0.9.0- Kodi 18 (LibreElec 9) installed on Raspberry Pi 3+, default Estuary skin- Emby for Kodi v4.06a (upgraded from v4.05 with library repair after upgrade) Symptom: Video playback on Kodi device starts. Video shows as direct playing from Kodi (LibreELEC) device in "Active Devices" section of Emby dashboard. Start of playback also identified in Emby "Activities" section of the dashboard. After a couple of seconds playback disappears from "Active Devices" and "Activities" identifies that playback has finished. Kodi continues to play the video. But playback status is not updated to "finished" in Emby when the video reaches the end. Everything works again after rolling back to Emby for Kodi v4.05 Logs attached. kodi.log embyserver.txt Edited February 19, 2019 by DarWun
Solution Angelblue05 4132 Posted February 20, 2019 Solution Posted February 20, 2019 I just posted a new beta. Please let me know if the issue persists with it. 1
DarWun 357 Posted February 20, 2019 Author Posted February 20, 2019 (edited) I just posted a new beta. Please let me know if the issue persists with it. Hi @@Angelblue05, Unfortunately the issue is not resolved after updating to Emby for Kodi v4.07a (and repairing libraries). I've attached new logs. Thanks, DarWun kodi.log embyserver.txt Edited February 21, 2019 by DarWun
DarWun 357 Posted February 26, 2019 Author Posted February 26, 2019 @@Angelblue05, I just updated to Emby for Kodi v4.09c. There is no change in the issue reported previously. After some testing, I found that playback from dynamic libraries is reported to Emby as expected. This is no longer the case once the library is synced to Kodi. The issue is resolved by reverting back to Emby for Kodi v4.05. Let me know if there is anything else I can provide to help troubleshoot this. Regards, DarWun 1
DarWun 357 Posted March 9, 2019 Author Posted March 9, 2019 @Angelblue05, After some additional troubleshooting, I found that playback works as expected when running Kodi for Emby in "Native Mode" with libraries synced to Kodi. Playback with synced libraries only seems to be a problem when running Kodi for Emby in "Add on" mode. Note: This is being reported with Emby for Kodi v4.0.12a. Regards, DarWun 1
