YTrailers install help
Go to solution Solved by rOis89,
Hi all,
today I downloaded the latest version of YTrailers from http://www.ballingtons.com/products/
Afterwards I uploaded the YTrailers.dll into /var/packages/EmbyServer/target/plugin using WinSCP, as described in the youtube video you already linked here.
Additionally I changed the permissions of the dll-file to 644
Is the path I uploaded the file on my synology correct?
After restarting Emby Server I was not able to find YTrailer unter "Plugins" in the Emby Settings.
How to configure the plugin and run the plugin to download the trailers?
Thanks a lot!
Edited by rOis89
  • Solution
Hi all,
i just solved my problem using the latetest YTrailer Plugin-In with Emby Server 4.4.2.0 on ym Synology Diskstation.
I recognized that I uploaded the YTrailers.dll into the wrong path.
After adding this file to "/var/packages/EmbyServer/target/var/plugin" instead of "/var/packages/EmbyServer/target/plugin" it is now working for me!
  • Like 1
