embyzone 5 Posted February 19, 2019 Posted February 19, 2019 Hi All Still working things out coming from Plex. First thing I wanted was a secure https certificate so I set up a Let's encrypt and a internal reverse proxy pointing to the new server. But! Emby keeps adding the port to my domain, which is included in the domain, https://domain.com:8920 Anyway to tell Emby to not use the port number in the link? (Writing nothing in the external port is a no go)
rbjtech 5338 Posted February 19, 2019 Posted February 19, 2019 .. change it under Advanced to 443 - the default SSL port and then it won't matter as https implies 443 anyway..
embyzone 5 Posted February 19, 2019 Author Posted February 19, 2019 .. change it under Advanced to 443 - the default SSL port and then it won't matter as https implies 443 anyway.. Yes, thats is a ok workaround, it will write the 443 but since its default the link works from inside Emby Any other security recommendations? (I have removed user names from login page)
