Emby for Kodi - Dodgy sound (sometimes)
Go to solution Solved by Angelblue05,
Hi,
I'm running Kodi 17.6 and Emby Server 4.0.1.0.
I recently re-built my Kodi box and my playback method is set to "Add On". Occasionally the soundtrack is distorted when playing back either a movie or tv show. (This never happened prior to the rebuild with my previous set up which was Native playback). Video playback is smooth btw, it's just the sound that is the problem.
I'm not sure where to start looking to try and resolve this. It doesn't happen all the time, and when it happens if I stop playback and then restart the problem disappears for a short while.
Could I have some help please as to where to look or what to provide to help resolve this?
Thanks
Edited by pjb
  • Solution
Angelblue05
@@pjb
In the add-on settings > playback > Disable Force http. Does the issue still happen?
  • Like 1
Thanks. I have made the change. I will report back if the problem re-occurs.
Are you able to please advise what is the function of this setting?
Edited by pjb
  • 3 weeks later...
This problem has not reoccurred since I made the change recommended by Angelblue05. I am marking as solved. Thanks very much for the help.
  • Like 1
Guest
