amack 1 Posted February 18, 2019 Posted February 18, 2019 (edited) Server ver 4.0.2.0 WMC Client 3.0.317 OS Win7 x64 I have one admin account with both a password and pin. After the last server upgrade the Emby WMC client asks for the PIN each time I run it in my local network. It also logs a failed login. After trial and error it seems to only remember the password but not the PIN even though you can type either. So the work around is to type the much longer and secure password when prompted after that its remembered and doesn't ask again. I have a two other accounts that have a password but no PIN and they are working as expected. My Roku clients are remembering the PIN as expected. The issue is just with the WMC client. The work around is fine, thought I should report the issue. Edited February 18, 2019 by elhuevon
Mark Wilson 0 Posted February 19, 2019 Posted February 19, 2019 I just hit this same issue. PIN is no longer working when signing into Emby with a client but the password is.Server version 4.0.2.0 Clients running 3.0.317 on both Windows 7 x64 and 8.1 x64Pin Reset does not work.Changing Pin does not work. Let me know if there is any other information you need.
rliepins 9 Posted February 24, 2019 Posted February 24, 2019 +1. Am uninstalling and reinstalling to see if that fixes the issue. Wife is not happy
rliepins 9 Posted February 27, 2019 Posted February 27, 2019 Is there any progress or is anyone aware of this issue? Sent from my iPhone using Tapatalk
ebr 16331 Posted February 27, 2019 Posted February 27, 2019 Is there any progress or is anyone aware of this issue? Sent from my iPhone using Tapatalk Hi. We're looking into it but can you tell us exactly what issue you are having? Did the workaround not work for you (using the true password once)?
rliepins 9 Posted February 27, 2019 Posted February 27, 2019 Hi and thanks for getting back to me. When I enter Emby from WMC, it always asks for the password or PIN: So, I can enter either the PIN or password (btw, the Security PIN always stays the same and won't go to password). Entering either gets me in, but when I back out and go back in, it always asks for the same info again. Another behavior is that once entering the credentials, it stalls for 10 to 20 seconds before entering the interface. However, that could just as easily be my system and not the app. Is there a log file for Emby for WMC I can upload? Thanks
ebr 16331 Posted February 27, 2019 Posted February 27, 2019 Yes, there is a log file. How to Report a Problem Did you configure the app to login automatically?
rliepins 9 Posted February 27, 2019 Posted February 27, 2019 Yes, I did. I also toggled several times to see if a reset would fix. In any case, I attached the log file MBClassic-2722019b8b169e2623d4479a2e5b7f252647119.log
ebr 16331 Posted February 27, 2019 Posted February 27, 2019 Thanks. We're going to have to take a look at this. One thing you could do as a workaround is blank out the EasyPIN in the server user configuration but keep the option checked. This will have the effect of allowing login from the local LAN without requiring the password. Since you are trying to bypass the password entry, this will get you what you want.
rliepins 9 Posted March 1, 2019 Posted March 1, 2019 Thanks, that worked. It also sped up the loading process.
