Hasi105 0 Posted February 18, 2019 Posted February 18, 2019 (edited) Hi,i got a StackOverflowException while starting the emby container in docker.I just add a libary and after 90% emby stuck and the container restarts.After the restert it stays on between 30-50s and it restarts again.Can somebody help me with a workaround or a solution? Serverlog.txt Edited February 18, 2019 by Hasi105
Luke 42246 Posted February 19, 2019 Posted February 19, 2019 Hi there, can you go here: /config/plugins And delete the anime plugin .dll file. Please let me know if that helps. Thanks.
Hasi105 0 Posted February 19, 2019 Author Posted February 19, 2019 (edited) It also didn't work before i had installed any plugins.I just removed the Anime.dll but it's still the same problem. Serverlog.txt Edited February 19, 2019 by Hasi105
Luke 42246 Posted February 19, 2019 Posted February 19, 2019 Did you install the correct docker container for your architecture? How did you install?
Hasi105 0 Posted February 19, 2019 Author Posted February 19, 2019 (edited) Did you install the correct docker container for your architecture? How did you install? I installed the Debian stretch OMV on to the Rock64 and than used the extensions to get docker. But ill try to reinstall it if there is a docker what is specifically for the Rock64 arch. My docker: xxx@rock64:~# docker version Client: Version: 18.09.2 API version: 1.39 Go version: go1.10.6 Git commit: 6247962 Built: Sun Feb 10 04:13:18 2019 OS/Arch: linux/arm64 Experimental: false Server: Docker Engine - Community Engine: Version: 18.09.2 API version: 1.39 (minimum version 1.12) Go version: go1.10.6 Git commit: 6247962 Built: Sun Feb 10 03:50:32 2019 OS/Arch: linux/arm64 Experimental: false Edited February 19, 2019 by Hasi105
Luke 42246 Posted February 20, 2019 Posted February 20, 2019 Maybe you ended up with our x64 docker container?
Luke 42246 Posted February 22, 2019 Posted February 22, 2019 Can you try removing the autoorganize plugin, and any others you may have added? thanks.
Hasi105 0 Posted February 22, 2019 Author Posted February 22, 2019 I got this problem even with a new created container (without plugins). I also tested yesterday to put onto debian itself via: wget https://github.com/MediaBrowser/Emby.Releases/releases/download/4.0.2.0/emby-server-deb_4.0.2.0_arm64.deb -O /tmp/emby-server-deb_4.0.2.0_arm64.deb && dpkg -i /tmp/emby-server-deb_4.0.2.0_arm64.deb ...After i had finished the installation with a created movie folder, it also stuck's and shut the service down.
Luke 42246 Posted March 19, 2019 Posted March 19, 2019 Can you try the beta server and see how that compares? Thanks.
waqasnasir 0 Posted October 24, 2019 Posted October 24, 2019 (edited) I was having the same issue with RockPro64 and it was restarting again and again on docker on OpenMediaVault. Initially i was trying EmbyServer AMD64 Later i realized it was a different architecture. Then i tried Emby Arm64 v8 and same restarting issue was there My third docker container was Emby Arm32 V7 and it is working fine. Update: After few minutes the Arm32 V7 also crashed and then restarting every 13 seconds. I deleted multiple times the docker instance and eventually it is not crashing .. But giving me error on every playback " No compatible streams are currently available. Please try again later or contact your system administrator for details. ". The folders thumbnails are all fine but nothing to play. Edited October 25, 2019 by waqasnasir
waqasnasir 0 Posted October 25, 2019 Posted October 25, 2019 (edited) Can anyone help me now with this error : Playback Error No compatible streams are currently available. Please try again later or contact your system administrator for details. All thumbnails are fine. I have plex running with the same hardware and using the same media folders with no issues since 1 year and without any crashing. Edited October 25, 2019 by waqasnasir
Luke 42246 Posted October 25, 2019 Posted October 25, 2019 Please attach the emby server log. Thanks.
waqasnasir 0 Posted October 27, 2019 Posted October 27, 2019 (edited) A line is saying that the movie is not found . How can a movie is not found when the thumbnails and meta data is all loaded. ffmpeg.rtf embyserver.rtf Edited October 27, 2019 by waqasnasir
Luke 42246 Posted October 27, 2019 Posted October 27, 2019 file:/mnt/share1/Kids Movies/Aladdin (2019)/Aladdin 2019.mp4: No such file or directory Is this on a file mount you've created? Is it possible the mount is down? It's either that, or Emby Server does not have permissions to read the contents of the video file. Can you check the permissions on the file?
waqasnasir 0 Posted October 28, 2019 Posted October 28, 2019 The mounts were fine . I think the folder permission or sharing violation might be the issue. I have the same Media folders used by Plex on RockPro64 OpenMediaVault where Plex is running as an OMV Extra Plugin , not in a docker . And after scratching my head for a considerable amount of time, i deleted everything and reinstalled the docker container of Emby and this time gave path to new fresh directory with initially no content and then I added one movie and synced the library it worked somehow. I dont know the issue was due to Plex folder sharing violation or some other thing .. but it is solved somehow and all is well that ends well ...
Luke 42246 Posted October 28, 2019 Posted October 28, 2019 Your permissions are probably set for whatever system user that other server runs under. Thanks for the feedback.
