hrehuhasdf 5 Posted February 18, 2019 Posted February 18, 2019 put.io is cloudstorage but only for torrent files. Would like to see if anyone has configured it with emby.
Damien_ 30 Posted February 20, 2019 Posted February 20, 2019 put.io is cloudstorage but only for torrent files. Would like to see if anyone has configured it with emby. I use put.io. I have for a couple years. I don’t understand the question though; it’s an application independent of Emby. What kind of configuration?
hrehuhasdf 5 Posted March 3, 2019 Author Posted March 3, 2019 (edited) I use put.io. I have for a couple years. I don’t understand the question though; it’s an application independent of Emby. What kind of configuration? So do you mount your put.io content as a linux mount using the webdav functionality? This way,you can specify that linux mount as a folder to scan within emby. Edited March 3, 2019 by tiedToAStar
Jetrois 0 Posted July 4, 2019 Posted July 4, 2019 I was looking for something like this as well more to inport from putio to my emby instance.
Damien_ 30 Posted July 5, 2019 Posted July 5, 2019 So do you mount your put.io content as a linux mount using the webdav functionality? This way,you can specify that linux mount as a folder to scan within emby. gotcha, like utilizing it as cloud storage instead of downloading it locally. I obviously haven't. Plex has a plugin so you could access and play content stored on put.io. But being able to mount it directly would be less kludgey than a plugin for sure.
pir8radio 1313 Posted July 5, 2019 Posted July 5, 2019 @@pir8radio have you tried this? I have used http://www.netdrive.net/ with emby for testing... But since it looks like a local drive to emby, you waste a lot of bandwidth with this. A client starts the streaming from your server, your emby server has to stream (downstream) the content into emby then restream (upstream) to the client. I recall some issues with getting consistent bandwidth from the could drive providers out there, resulting in lots of playback issues. But I have not tried it in a long time.
