eyeofthetiger41@gmail.com 0 Posted February 17, 2019 Posted February 17, 2019 Software directions from tv onscreen connect still says "Go to HTTP//Emby.media/pin". That is no longer the correct address as of yesterday. Now it is "HTTP//Emby.media/pin.html"
Luke 42217 Posted February 18, 2019 Posted February 18, 2019 Hi, actually it does still work. You can use: https://emby.media/pin And it will just redirect you to: https://emby.media/pin.html So either is fine. Please let us know if this helps. Thanks.
