sping@adelphia.net 0 Posted May 6, 2014 Posted May 6, 2014 I'm having issues playing WTV files through ROKU. I thought this was working at one time, but now it hangs. The same file plays fine through the browser. My version is Version 3.0.5233.40306. Below is the transcode log. server log attached. Any ideas? C:\Users\user1\AppData\Roaming\MediaBrowser-Server\ffmpeg\20140304\ffmpeg.exe -fflags genpts -async 1 -vsync -1 -i file:"C:\Users\Public\Recorded TV\Believe_WLEXDT_2014_05_04_20_58_00.wtv" -map_metadata -1 -threads 2 -sn -codec:v:0 libx264 -preset ultrafast -crf 23 -maxrate 3200000 -bufsize 6400000 -vsync vfr -profile:v high -level 4.0 -force_key_frames expr:if(isnan(prev_forced_t),gte(t,.1),gte(t,prev_forced_t+5)) -vf "yadif=0:-1:0,scale=trunc(min(iw\,1920)/2)*2:trunc(min((iw/dar)\,1080)/2)*2" -sc_threshold 0 -codec:a:0 aac -strict experimental -hls_time 10 -start_number 0 -hls_list_size 1440 "C:\Users\user1\AppData\Roaming\MediaBrowser-Server\transcoding-temp\f33063c1-4d8a-ef03-f473-c03f2cee6dd9.m3u8" ffmpeg version N-61061-gf34cceb Copyright © 2000-2014 the FFmpeg developers built on Mar 4 2014 00:44:56 with gcc 4.8.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-zlib libavutil 52. 66.101 / 52. 66.101 libavcodec 55. 52.102 / 55. 52.102 libavformat 55. 33.101 / 55. 33.101 libavdevice 55. 11.100 / 55. 11.100 libavfilter 4. 2.100 / 4. 2.100 libswscale 2. 5.101 / 2. 5.101 libswresample 0. 18.100 / 0. 18.100 libpostproc 52. 3.100 / 52. 3.100 [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error [h264 @ 027e3000] no frame! [h264 @ 027e3000] non-existing PPS 0 referenced Last message repeated 1 times [h264 @ 027e3000] decode_slice_header error Input #0, wtv, from 'file:C:\Users\Public\Recorded TV\Believe_WLEXDT_2014_05_04_20_58_00.wtv': Metadata: WM/MediaClassPrimaryID: db9830bd-3ab3-4fab-8a371a995f7ff74 WM/MediaClassSecondaryID: ba7f258a-62f7-47a9-b21f4651c42a000 Title : Believe WM/SubTitle : Prodigy WM/SubTitleDescription: A premonition of a musical prodigy's death sidetracks Tate's efforts to keep Bo focused on her training; Winter sets a contingency plan in motion; Skouras tests Dani's powers. genre : Drama;General;Series WM/OriginalReleaseTime: 0 WM/MediaCredits : Johnny Sequoyah/Jake McLaughlin/Delroy Lindo/Kyle MacLachlan/Jamie Chung/Arian Moayed;;;Mia Vallet/Kerry Condon/Trieste Kelly Dunn service_provider: WLEXDT service_name : WLEXDT (WLEX-DT) WM/MediaNetworkAffiliation: NBC Affiliate WM/MediaOriginalChannel: 18 WM/MediaOriginalChannelSubNumber: 1 WM/MediaOriginalBroadcastDateTime: 2014-05-04T04:00:00Z WM/MediaOriginalRunTime: 38387064000 WM/MediaIsStereo: true WM/MediaIsRepeat: false WM/MediaIsLive : false WM/MediaIsTape : false WM/MediaIsDelay : false WM/MediaIsSubtitled: false WM/MediaIsMovie : false WM/MediaIsPremiere: false WM/MediaIsFinale: false WM/MediaIsSAP : false WM/MediaIsSport : false WM/ParentalRating: TV-14 WM/Provider : MediaCenterDefault WM/VideoClosedCaptioning: false WM/WMRVEncodeTime: 2014-05-05 00:58:01 WM/WMRVSeriesUID: !MCSeries!289469067 WM/WMRVServiceID: !MCService!45422122 WM/WMRVProgramID: !MCProgram!299717843 WM/WMRVRequestID: 0 WM/WMRVScheduleItemID: 0 WM/WMRVQuality : 3 WM/WMRVOriginalSoftPrePadding: 420 WM/WMRVOriginalSoftPostPadding: 120 WM/WMRVHardPrePadding: -300 WM/WMRVHardPostPadding: 0 WM/WMRVATSCContent: true WM/WMRVDTVContent: true WM/WMRVHDContent: true Duration : 38392330000 WM/WMRVEndTime : 2014-05-05 02:02:00 WM/WMRVBitrate : 7.452931 WM/WMRVKeepUntil: -1 WM/WMRVActualSoftPrePadding: 418 WM/WMRVActualSoftPostPadding: 120 WM/WMRVContentProtected: false WM/WMRVContentProtectedPercent: 0 WM/WMRVExpirationSpan: 9223372036854775807 WM/WMRVInBandRatingSystem: 255 WM/WMRVInBandRatingLevel: 255 WM/WMRVInBandRatingAttributes: 0 WM/WMRVWatched : false WM/MediaThumbWidth: 352 WM/MediaThumbHeight: 198 WM/MediaThumbStride: 1056 WM/MediaThumbRet: 0 WM/MediaThumbRatingSystem: 9 WM/MediaThumbRatingLevel: 14 WM/MediaThumbRatingAttributes: 0 WM/MediaThumbAspectRatioX: 1920 WM/MediaThumbAspectRatioY: 1080 WM/MediaThumbTimeStamp: 4643876831425119500 Duration: 01:03:58.51, start: 1.854023, bitrate: 7454 kb/s Stream #0:0[0x20](eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s Stream #0:1[0x21]: Video: h264 (High), yuv420p(tv, bt709), 1920x1080 [sAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 10000k tbn, 59.94 tbc Stream #0:2[0x22]: Subtitle: eia_608 -async is forwarded to lavfi similarly to -af aresample=async=1:min_hard_comp=0.100000:first_pts=0. [libx264 @ 04ac3ec0] using SAR=1/1 [libx264 @ 04ac3ec0] using cpu capabilities: MMX2 SSE2Fast LZCNT [libx264 @ 04ac3ec0] profile Constrained Baseline, level 4.0 Output #0, hls, to 'C:\Users\user1\AppData\Roaming\MediaBrowser-Server\transcoding-temp\f33063c1-4d8a-ef03-f473-c03f2cee6dd9.m3u8': Metadata: encoder : Lavf55.33.101 Stream #0:0: Video: h264 (libx264), yuv420p, 1920x1080 [sAR 1:1 DAR 16:9], q=-1--1, max. 3200 kb/s, 90k tbn, 29.97 tbc Stream #0:1: Audio: aac, 48000 Hz, 5.1(side), fltp, 128 kb/s Stream mapping: Stream #0:1 -> #0:0 (h264 -> libx264) Stream #0:0 -> #0:1 (ac3 -> aac) Press [q] to stop, [?] for help [adts @ 05c92320] Encoder did not produce proper pts, making some up. frame= 12 fps=0.0 q=22.0 size=N/A time=00:00:02.53 bitrate=N/A frame= 39 fps= 38 q=24.0 size=N/A time=00:00:03.43 bitrate=N/A frame= 67 fps= 44 q=27.0 size=N/A time=00:00:04.37 bitrate=N/A frame= 94 fps= 46 q=24.0 size=N/A time=00:00:05.27 bitrate=N/A frame= 122 fps= 48 q=22.0 size=N/A time=00:00:06.20 bitrate=N/A frame= 150 fps= 49 q=22.0 size=N/A time=00:00:07.14 bitrate=N/A frame= 179 fps= 50 q=23.0 size=N/A time=00:00:08.10 bitrate=N/A frame= 206 fps= 51 q=25.0 size=N/A time=00:00:09.00 bitrate=N/A frame= 235 fps= 52 q=24.0 size=N/A time=00:00:09.97 bitrate=N/A frame= 262 fps= 52 q=24.0 size=N/A time=00:00:10.87 bitrate=N/A frame= 291 fps= 52 q=25.0 size=N/A time=00:00:11.84 bitrate=N/A frame= 320 fps= 53 q=24.0 size=N/A time=00:00:12.81 bitrate=N/A frame= 347 fps= 53 q=25.0 size=N/A time=00:00:13.71 bitrate=N/A frame= 375 fps= 53 q=22.0 size=N/A time=00:00:14.64 bitrate=N/A frame= 403 fps= 53 q=22.0 size=N/A time=00:00:15.58 bitrate=N/A frame= 430 fps= 53 q=22.0 size=N/A time=00:00:16.48 bitrate=N/A frame= 458 fps= 53 q=23.0 size=N/A time=00:00:17.41 bitrate=N/A frame= 485 fps= 53 q=23.0 size=N/A time=00:00:18.31 bitrate=N/A frame= 514 fps= 54 q=23.0 size=N/A time=00:00:19.28 bitrate=N/A frame= 544 fps= 54 q=25.0 size=N/A time=00:00:20.28 bitrate=N/A frame= 573 fps= 54 q=24.0 size=N/A time=00:00:21.25 bitrate=N/A frame= 603 fps= 54 q=21.0 size=N/A time=00:00:22.25 bitrate=N/A frame= 632 fps= 54 q=24.0 size=N/A time=00:00:23.22 bitrate=N/A frame= 660 fps= 54 q=23.0 size=N/A time=00:00:24.15 bitrate=N/A frame= 690 fps= 55 q=27.0 size=N/A time=00:00:25.15 bitrate=N/A frame= 716 fps= 54 q=28.0 size=N/A time=00:00:26.02 bitrate=N/A frame= 745 fps= 54 q=28.0 size=N/A time=00:00:26.99 bitrate=N/A frame= 774 fps= 55 q=29.0 size=N/A time=00:00:27.96 bitrate=N/A frame= 802 fps= 55 q=28.0 size=N/A time=00:00:28.89 bitrate=N/A frame= 829 fps= 55 q=29.0 size=N/A time=00:00:29.79 bitrate=N/A frame= 857 fps= 55 q=30.0 size=N/A time=00:00:30.73 bitrate=N/A frame= 885 fps= 55 q=34.0 size=N/A time=00:00:31.66 bitrate=N/A frame= 914 fps= 55 q=27.0 size=N/A time=00:00:32.63 bitrate=N/A frame= 943 fps= 55 q=25.0 size=N/A time=00:00:33.60 bitrate=N/A frame= 972 fps= 55 q=25.0 size=N/A time=00:00:34.56 bitrate=N/A frame= 998 fps= 55 q=26.0 size=N/A time=00:00:35.43 bitrate=N/A frame= 1027 fps= 55 q=25.0 size=N/A time=00:00:36.40 bitrate=N/A frame= 1055 fps= 55 q=27.0 size=N/A time=00:00:37.33 bitrate=N/A frame= 1084 fps= 55 q=22.0 size=N/A time=00:00:38.30 bitrate=N/A frame= 1113 fps= 55 q=22.0 size=N/A time=00:00:39.27 bitrate=N/A frame= 1140 fps= 55 q=31.0 size=N/A time=00:00:40.17 bitrate=N/A frame= 1168 fps= 55 q=27.0 size=N/A time=00:00:41.10 bitrate=N/A frame= 1198 fps= 55 q=26.0 size=N/A time=00:00:42.10 bitrate=N/A frame= 1228 fps= 55 q=28.0 size=N/A time=00:00:43.10 bitrate=N/A frame= 1256 fps= 55 q=18.0 size=N/A time=00:00:44.04 bitrate=N/A frame= 1282 fps= 55 q=29.0 size=N/A time=00:00:44.91 bitrate=N/A frame= 1311 fps= 55 q=27.0 size=N/A time=00:00:45.87 bitrate=N/A frame= 1340 fps= 55 q=27.0 size=N/A time=00:00:46.84 bitrate=N/A frame= 1369 fps= 55 q=28.0 size=N/A time=00:00:47.81 bitrate=N/A frame= 1398 fps= 55 q=29.0 size=N/A time=00:00:48.78 bitrate=N/A frame= 1427 fps= 55 q=27.0 size=N/A time=00:00:49.74 bitrate=N/A frame= 1454 fps= 55 q=43.0 size=N/A time=00:00:50.65 bitrate=N/A frame= 1481 fps= 55 q=42.0 size=N/A time=00:00:51.55 bitrate=N/A frame= 1508 fps= 55 q=43.0 size=N/A time=00:00:52.45 bitrate=N/A frame= 1535 fps= 55 q=40.0 size=N/A time=00:00:53.35 bitrate=N/A frame= 1562 fps= 55 q=44.0 size=N/A time=00:00:54.25 bitrate=N/A frame= 1591 fps= 55 q=26.0 size=N/A time=00:00:55.22 bitrate=N/A frame= 1620 fps= 55 q=26.0 size=N/A time=00:00:56.18 bitrate=N/A frame= 1648 fps= 55 q=22.0 size=N/A time=00:00:57.12 bitrate=N/A frame= 1677 fps= 55 q=24.0 size=N/A time=00:00:58.09 bitrate=N/A frame= 1706 fps= 55 q=24.0 size=N/A time=00:00:59.05 bitrate=N/A frame= 1735 fps= 55 q=24.0 size=N/A time=00:01:00.02 bitrate=N/A frame= 1764 fps= 55 q=23.0 size=N/A time=00:01:00.99 bitrate=N/A frame= 1791 fps= 55 q=25.0 size=N/A time=00:01:01.89 bitrate=N/A frame= 1820 fps= 55 q=25.0 size=N/A time=00:01:02.86 bitrate=N/A frame= 1848 fps= 55 q=25.0 size=N/A time=00:01:03.79 bitrate=N/A frame= 1876 fps= 55 q=26.0 size=N/A time=00:01:04.73 bitrate=N/A frame= 1905 fps= 55 q=25.0 size=N/A time=00:01:05.69 bitrate=N/A frame= 1931 fps= 55 q=25.0 size=N/A time=00:01:06.56 bitrate=N/A frame= 1960 fps= 55 q=25.0 size=N/A time=00:01:07.53 bitrate=N/A frame= 1987 fps= 55 q=30.0 size=N/A time=00:01:08.43 bitrate=N/A frame= 2016 fps= 55 q=27.0 size=N/A time=00:01:09.40 bitrate=N/A frame= 2045 fps= 55 q=27.0 size=N/A time=00:01:10.37 bitrate=N/A frame= 2074 fps= 55 q=25.0 size=N/A time=00:01:11.33 bitrate=N/A frame= 2102 fps= 55 q=27.0 size=N/A time=00:01:12.27 bitrate=N/A frame= 2131 fps= 55 q=26.0 size=N/A time=00:01:13.23 bitrate=N/A frame= 2159 fps= 55 q=28.0 size=N/A time=00:01:14.17 bitrate=N/A frame= 2186 fps= 55 q=29.0 size=N/A time=00:01:15.07 bitrate=N/A frame= 2212 fps= 55 q=29.0 size=N/A time=00:01:15.94 bitrate=N/A frame= 2239 fps= 55 q=29.0 size=N/A time=00:01:16.84 bitrate=N/A frame= 2266 fps= 55 q=28.0 size=N/A time=00:01:17.74 bitrate=N/A frame= 2293 fps= 55 q=35.0 size=N/A time=00:01:18.64 bitrate=N/A frame= 2318 fps= 55 q=29.0 size=N/A time=00:01:19.47 bitrate=N/A frame= 2346 fps= 55 q=28.0 size=N/A time=00:01:20.41 bitrate=N/A frame= 2374 fps= 55 q=28.0 size=N/A time=00:01:21.34 bitrate=N/A frame= 2401 fps= 55 q=29.0 size=N/A time=00:01:22.24 bitrate=N/A frame= 2429 fps= 55 q=28.0 size=N/A time=00:01:23.18 bitrate=N/A frame= 2459 fps= 55 q=27.0 size=N/A time=00:01:24.18 bitrate=N/A frame= 2487 fps= 55 q=24.0 size=N/A time=00:01:25.11 bitrate=N/A frame= 2513 fps= 55 q=29.0 size=N/A time=00:01:25.98 bitrate=N/A frame= 2540 fps= 55 q=28.0 size=N/A time=00:01:26.88 bitrate=N/A frame= 2567 fps= 55 q=28.0 size=N/A time=00:01:27.78 bitrate=N/A frame= 2593 fps= 55 q=26.0 size=N/A time=00:01:28.65 bitrate=N/A frame= 2620 fps= 55 q=27.0 size=N/A time=00:01:29.55 bitrate=N/A frame= 2647 fps= 55 q=26.0 size=N/A time=00:01:30.45 bitrate=N/A frame= 2676 fps= 55 q=24.0 size=N/A time=00:01:31.42 bitrate=N/A frame= 2704 fps= 55 q=26.0 size=N/A time=00:01:32.35 bitrate=N/A frame= 2732 fps= 55 q=23.0 size=N/A time=00:01:33.29 bitrate=N/A frame= 2758 fps= 55 q=28.0 size=N/A time=00:01:34.16 bitrate=N/A frame= 2783 fps= 55 q=31.0 size=N/A time=00:01:34.99 bitrate=N/A frame= 2810 fps= 55 q=29.0 size=N/A time=00:01:35.89 bitrate=N/A frame= 2838 fps= 55 q=29.0 size=N/A time=00:01:36.83 bitrate=N/A frame= 2865 fps= 55 q=41.0 size=N/A time=00:01:37.73 bitrate=N/A frame= 2893 fps= 55 q=29.0 size=N/A time=00:01:38.66 bitrate=N/A frame= 2923 fps= 55 q=35.0 size=N/A time=00:01:39.66 bitrate=N/A frame= 2952 fps= 55 q=36.0 size=N/A time=00:01:40.63 bitrate=N/A frame= 2981 fps= 55 q=29.0 size=N/A time=00:01:41.60 bitrate=N/A frame= 3010 fps= 55 q=31.0 size=N/A time=00:01:42.56 bitrate=N/A frame= 3039 fps= 55 q=34.0 size=N/A time=00:01:43.53 bitrate=N/A frame= 3065 fps= 55 q=26.0 size=N/A time=00:01:44.40 bitrate=N/A server-63534844800_suport.zip
gcw07 347 Posted May 6, 2014 Posted May 6, 2014 Our ffmpeg person @@Luke will have to answer that one for you.
Luke 42241 Posted May 7, 2014 Posted May 7, 2014 can you define hangs, because according to the server log, ffmpeg stopped because it was instructed to do so by the client. so it sounds like video was not responsive on screen, so you stopped it. is that correct?
techywarrior 689 Posted May 7, 2014 Posted May 7, 2014 I just noticed an issue with wtv files as well. Mine play on safari and roku but there is no audio. Played in IE perfectly. I am on vacation so I can't get logs right now.
lordbond 2 Posted May 12, 2014 Posted May 12, 2014 I am having problems with some files. I tried watching a NASCAR race I recorded and it kept loading the first couple of seconds and stop, load the recording, play the first couple of seconds and repeat until I stopped it. I tried playing a shorter (1/2 hour, low def. program) and it played fine.
sping@adelphia.net 0 Posted May 13, 2014 Author Posted May 13, 2014 By hangs, I mean that roku never streams the video. It will stay on the screen with the retrieving status either at 100%, or just under. I did notice that the transcoding-temp table will add .tc files (around 4 megs) as long as I don't cancel from the roku player.
mdavej 0 Posted September 12, 2014 Posted September 12, 2014 Any new developments? I'm also trying to play wtv files on Roku 1 and get great video, but no audio. Using latest windows server beta. How should my library be set up? All I did was install the server and add my recorded TV folder as Movies & TV type. Thanks
