Luke 42246 Posted May 5, 2018 Posted May 5, 2018 Maybe it's getting stuck trying to access a drive? Have you considered running hardware diagnostics to look for drive failures?
pr3dict 33 Posted May 5, 2018 Author Posted May 5, 2018 Maybe it's getting stuck trying to access a drive? Have you considered running hardware diagnostics to look for drive failures? I run a smart test every morning at 3AM. Everything is fine from that perspective. Maybe permissions? but if that was the case then it would never work?
Luke 42246 Posted May 5, 2018 Posted May 5, 2018 What about full surface scans of the disks? For starters I would turn off as many functions as possible that are going to access those disks, such as chapter image extraction, local metadata saving, cover art plugin if you have that, Roku plugin if you have that, real-time monitor, etc.
pr3dict 33 Posted May 5, 2018 Author Posted May 5, 2018 What about full surface scans of the disks? For starters I would turn off as many functions as possible that are going to access those disks, such as chapter image extraction, local metadata saving, cover art plugin if you have that, Roku plugin if you have that, real-time monitor, etc. So I have Metadata going to my storage server. The local cache is on a separate also local drive which is an SSD. I can turn of chapter image extraction but I just dont see how to literally diagnpose/fix this. This wasnt an issue until recent.
pr3dict 33 Posted May 5, 2018 Author Posted May 5, 2018 Also is this normal? When unchecking a field the color change sticks around even after moving the mouse away.
pr3dict 33 Posted May 8, 2018 Author Posted May 8, 2018 awkward... But I fixed it... My fault or more PFSense fault. That ^^^^^ needed to be unchecked in my DNS resolver. When that was checked which I have checked I guess recently. Well it broke stuff. Everything is zipping away and even my non https emby stuff is working. Before it kinda crapped out.
pr3dict 33 Posted May 19, 2018 Author Posted May 19, 2018 I spoke too soon. Its still going super slow and being unresponsive to some clicks
pr3dict 33 Posted May 19, 2018 Author Posted May 19, 2018 not to be annoying but Ive given you 3 logs already lol. nothing has changed on my end.
pr3dict 33 Posted August 2, 2018 Author Posted August 2, 2018 FYI - This is still a disaster... Attached another log. pages don't load, hang, and just generally don't even work at all when clicked. embysomanyerrors.txt
Luke 42246 Posted August 2, 2018 Posted August 2, 2018 Can you try over http and see how that compares? thanks.
pr3dict 33 Posted August 2, 2018 Author Posted August 2, 2018 Can you try over http and see how that compares? thanks. going to http I couldnt even get off the home screen. clicking on any of the other links wouldnt work at all. I get off the home screen this time but it has the same symptoms.
testbug 3 Posted August 2, 2018 Posted August 2, 2018 Just thought I'd mention that I don't have my issues anymore after updating from 3.3.1.0 to 3.5.2.0. The only thing I've changed was disabling DLNA. Might be something you could try pr3dict.
Luke 42246 Posted August 3, 2018 Posted August 3, 2018 Ok, please try again with the next release of Emby Server as there will be major performance improvements. Thanks.
pr3dict 33 Posted August 3, 2018 Author Posted August 3, 2018 Doesnt this seem like more of a specific issue then just a performance issue? There are like over 1000 errors in that file.
Luke 42246 Posted August 3, 2018 Posted August 3, 2018 Yea the errors I'm not quite sure about, so yes it could be something other than performance. Connection reset by peer Means that a client device got something it didn't like. It could be ssl certificate related.
Luke 42246 Posted August 3, 2018 Posted August 3, 2018 Similar error messages in this ticket on the .net core repo: https://github.com/dotnet/corefx/issues/29620 Granted, Connection reset by peer could mean any number of different things so just because the error message is the same, doesn't mean the problem is.
pr3dict 33 Posted August 3, 2018 Author Posted August 3, 2018 It may have something to do with live tv? As soon as I hit the livetv tab lately everything just dies. Super slow and everytime i go to a page for the next minute afterward it just half loads or doesnt load at all. Also, none of the channels are listed int he channels view. The guide has channels with no programs or time slots. None of the channel logos are showing up.... The metadata manager shows all of the channels though.
pr3dict 33 Posted August 3, 2018 Author Posted August 3, 2018 Nope its zippy if I'm just cruising through the other sections. Its when I get to a page that like doesnt want to load (like live tv) and then I try to go anywhere else, it just like cancer. just breaks all the other pages after that.
Luke 42246 Posted August 3, 2018 Posted August 3, 2018 Ok, well that will be considerably faster with the next release.
