TheBrainninja 0 Posted February 16, 2019 Posted February 16, 2019 Since the 4.0 (and onward) upgrade, I've been missing the "Movies and TV View for these libraries" option for my home screen. Is this option returning? I use several mixed-content libraries, and while I'm happy with my file sorting method, the ability to dynamically collate them into Movies and TV in software really helped for end-user accessibility.
Solution Luke 42246 Posted February 16, 2019 Solution Posted February 16, 2019 It's not returning. I would suggest using the dedicated content types, or wait until we have a smart views/playlists feature and then you can design your own. 1
