Blatherscribe 5 Posted February 15, 2019 Posted February 15, 2019 Greetings, I've just installed Emby on my computer and Roku, and I've found that it plays movies in the wrong aspect ratio. It automatically "corrects" to 16:9 to match my TV, but the movie in question is in 1.85:1 format. There should be small black bars at the top and bottom of the screen, but this fills the screen, and thus cuts off the ends of the image. I switched to Emby from Plex because there was no way to fix this in Plex. Is there a way to make Emby display the native aspect ratio for a video? I should note that I was careful not to use an anamorphic video, just in case: it was saved at the resolution at which it is meant to play. It's just that Emby zooms in whether I want it to or not.
Luke 42242 Posted February 15, 2019 Posted February 15, 2019 Hi there, is this only in the Roku app? How does it compare in the web app? Thanks !
Blatherscribe 5 Posted February 15, 2019 Author Posted February 15, 2019 I just checked, and it's fine in the web app. So only the Roku app is automatically zooming in.
Luke 42242 Posted February 15, 2019 Posted February 15, 2019 Is it direct playing in the Roku app? If yes then this means it is a Roku platform defect. The only thing we could do is fix via server transcoding. Thanks.
Blatherscribe 5 Posted February 15, 2019 Author Posted February 15, 2019 How can I tell? I can't find any settings for direct playing.
Happy2Play 9811 Posted February 15, 2019 Posted February 15, 2019 What does the server dashboard show while playing this media. I believe you have to enable a setting in the Roku app (don't recall exactly then name) and the OSD will tell you playback method if you hit the down arrow while item is playing.
Blatherscribe 5 Posted February 16, 2019 Author Posted February 16, 2019 It was on direct play, but I've tried the "playback correction" option, setting it to "remux" and "transcode," with no difference. Any suggestions there? If not, well, at least Emby understands that I don't ALWAYS want subtitles, so that's a huge improvement over Plex.
Luke 42242 Posted February 16, 2019 Posted February 16, 2019 Are you sure it was transcoding? Can you attach the ffmpeg log? Thanks.
Blatherscribe 5 Posted February 16, 2019 Author Posted February 16, 2019 Sure, here's one. I should note that I'm not sure about ANYTHING. I just selected the "playback correction" option on the Roku, and it changed to "transcode." Also, a strangeness: when I press the asterisk button on the Roku, in order to pull up the subtitle and playback options, it's a struggle. Most of the time it flashes on the screen and immediately off again. It can take many attempts to get it to work. Just mentioning it in case it's something you know how to fix, otherwise I can work with it. Thank you for all the help! 2019-02-15 19:28:21.265 Application version: 4.0.2.0 http://192.168.0.20:8096/emby/videos/11/hls1/main/326.ts?DeviceId=a9cf8f34-3526-5183-9494-7051426c06ca&MediaSourceId=747d2c0b94e1472d4eb55b2bb52e21d8&VideoCodec=h264&AudioCodec=ac3,aac,mp2,mp3,flac,opus,vorbis,lpcm&VideoBitrate=79808000&AudioBitrate=192000&MaxFramerate=61&MaxWidth=1920&MaxHeight=1080&PlaySessionId=15843788de5645da908d673f37381180&api_key=ff4b07c788024793a28249a5de656b25&AudioStreamIndex=1&SubtitleMethod=Encode&TranscodingMaxAudioChannels=6&SegmentContainer=ts&SegmentLength=3&MinSegments=1&BreakOnNonKeyFrames=True&h264-maxrefframes=16&h264-videobitdepth=8&h264-profile=high,main,baseline,constrainedbaseline&h264-level=51&aac-audiochannels=2&ac3-audiochannels=6&flac-audiochannels=6&lpcm-audiochannels=6&mp3-audiochannels=2&mp2-audiochannels=2&vorbis-audiochannels=6&opus-audiochannels=6&AllowVideoStreamCopy=False {"Protocol":"File","Id":"747d2c0b94e1472d4eb55b2bb52e21d8","Path":"D:\\Videos\\Movies\\Young Frankenstein.mkv","Type":"Default","Container":"mkv","Size":15938161356,"Name":"Young Frankenstein","IsRemote":false,"RunTimeTicks":63410130944,"ReadAtNativeFramerate":false,"DiscardCorruptPts":false,"FillWallClockDts":false,"IgnoreDts":false,"IgnoreIndex":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":true,"MediaStreams":[{"Codec":"h264","ColorTransfer":"bt709","ColorPrimaries":"bt709","ColorSpace":"bt709","TimeBase":"1/1000","CodecTimeBase":"1001/48000","VideoRange":"SDR","DisplayTitle":"1080p H264","NalLengthSize":"4","IsInterlaced":false,"IsAVC":true,"BitRate":20108031,"BitDepth":8,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":1040,"Width":1920,"AverageFrameRate":23.9760246,"RealFrameRate":23.9760246,"Profile":"Main","Type":"Video","AspectRatio":"1.85:1","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"PixelFormat":"yuv420p","Level":40,"IsAnamorphic":false},{"Codec":"aac","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"1/48000","Title":"Stereo","DisplayTitle":"Eng AAC stereo Default","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"LC","Type":"Audio","Index":1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0},{"Codec":"PGSSUB","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"Eng","IsInterlaced":false,"IsDefault":false,"IsForced":false,"Type":"Subtitle","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Level":0}],"Formats":[],"Bitrate":20108031,"RequiredHttpHeaders":{}} User policy for Name: EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True Affected codecs: >>>>>> libx264 Software Encoder Color Formats: YUV420P, YUVJ420P, YUV422P, YUVJ422P, YUV444P, YUVJ444P, NV12, NV16, NV21, YUV420P10LE, YUV422P10LE, YUV444P10LE, NV20LE Profiles: Baseline Profile (Level 6.2), Main Profile (Level 6.2), High Profile (Level 6.2), High 10 Profile (Level 6.2), High 4:2:2 Profile (Level 6.2), High 4:4:4 Profile (Level 6.2) >>>>>> FindVideoDecoder - MediaType: h264, Mode: 1 Info FindVideoDecoder - Checking: 'Automatic software decoder' (Priority: 0) Info FindVideoDecoder - Check successful - selecting 'Automatic software decoder' >>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: 1 Info FindVideoEncoder - Checking: 'libx264 Software Encoder' (Priority: 0) Info Encoder supports input stream Info FindVideoEncoder - Check successful - selecting 'libx264 Software Encoder' >>>>>> FindVideoDecoder - MediaType: h264, Mode: 1 Info FindVideoDecoder - Checking: 'Automatic software decoder' (Priority: 0) Info FindVideoDecoder - Check successful - selecting 'Automatic software decoder' >>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: 1 Info FindVideoEncoder - Checking: 'libx264 Software Encoder' (Priority: 0) Info Encoder supports input stream Info FindVideoEncoder - Check successful - selecting 'libx264 Software Encoder' C:\Users\name\AppData\Roaming\Emby-Server\system\ffmpeg.exe -ss 00:16:18.000 -f matroska -i file:"D:\Videos\Movies\Young Frankenstein.mkv" -threads 0 -map 0:0 -map 0:1 -map -0:s -c:v:0 libx264 -filter_complex "[0:0]scale=trunc(min(max(iw\,ih*dar)\,min(1920\,1080*dar))/2)*2:trunc(min(max(iw/dar\,ih)\,min(1920/dar\,1080))/2)*2" -pix_fmt yuv420p -maxrate 20108031 -bufsize 40216062 -preset veryfast -profile high -level 4.1 -crf 23 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -force_key_frames "expr:if(isnan(prev_forced_t),eq(t,t),gte(t,prev_forced_t+3))" -copyts -vsync -1 -codec:a:0 copy -metadata:s:a:0 language=eng -disposition:a:0 default -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 3 -segment_time_delta -978 -individual_header_trailer 0 -segment_format mpegts -segment_list_type m3u8 -segment_start_number 326 -segment_list "C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8" -y "C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05%d.ts" ffmpeg version 4.0.2-emby_2018_12_09-g5abbb1430d+238 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 8.2.1 (Rev1, Built by MSYS2 project) 20181207 configuration: --disable-autodetect --enable-amf --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --enable-sdl2 --disable-debug --enable-ffnvcodec --enable-nvdec --enable-gmp --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwavpack --enable-libwebp --enable-libxml2 --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libaom --enable-version3 --enable-libzvbi --enable-gnutls --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++ --extra-cflags=-DLIBXML_STATIC --extra-libs=-liconv libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100 [matroska,webm @ 000002785d7bdd40] Could not find codec parameters for stream 2 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, matroska,webm, from 'file:D:\Videos\Movies\Young Frankenstein.mkv': Metadata: creation_time : 2019-02-14T21:08:12.000000Z ENCODER : Lavf58.20.100 Duration: 01:45:41.01, start: 0.000000, bitrate: 20108 kb/s Chapter #0:0: start 0.000000, end 308.809000 Metadata: title : Chapter 1 Chapter #0:1: start 308.809000, end 728.645000 Metadata: title : Chapter 2 Chapter #0:2: start 728.645000, end 906.948000 Metadata: title : Chapter 3 Chapter #0:3: start 906.948000, end 1145.895000 Metadata: title : Chapter 4 Chapter #0:4: start 1145.895000, end 1425.341000 Metadata: title : Chapter 5 Chapter #0:5: start 1425.341000, end 1707.748000 Metadata: title : Chapter 6 Chapter #0:6: start 1707.748000, end 2024.606000 Metadata: title : Chapter 7 Chapter #0:7: start 2024.606000, end 2136.051000 Metadata: title : Chapter 8 Chapter #0:8: start 2136.051000, end 2379.002000 Metadata: title : Chapter 9 Chapter #0:9: start 2379.002000, end 2454.327000 Metadata: title : Chapter 10 Chapter #0:10: start 2454.327000, end 2904.777000 Metadata: title : Chapter 11 Chapter #0:11: start 2904.777000, end 3071.277000 Metadata: title : Chapter 12 Chapter #0:12: start 3071.277000, end 3134.423000 Metadata: title : Chapter 13 Chapter #0:13: start 3134.423000, end 3500.247000 Metadata: title : Chapter 14 Chapter #0:14: start 3500.247000, end 3692.439000 Metadata: title : Chapter 15 Chapter #0:15: start 3692.439000, end 3896.393000 Metadata: title : Chapter 16 Chapter #0:16: start 3896.393000, end 3995.158000 Metadata: title : Chapter 17 Chapter #0:17: start 3995.158000, end 4278.483000 Metadata: title : Chapter 18 Chapter #0:18: start 4278.483000, end 4603.891000 Metadata: title : Chapter 19 Chapter #0:19: start 4603.891000, end 5031.610000 Metadata: title : Chapter 20 Chapter #0:20: start 5031.610000, end 5141.178000 Metadata: title : Chapter 21 Chapter #0:21: start 5141.178000, end 5330.492000 Metadata: title : Chapter 22 Chapter #0:22: start 5330.492000, end 5392.554000 Metadata: title : Chapter 23 Chapter #0:23: start 5392.554000, end 5501.830000 Metadata: title : Chapter 24 Chapter #0:24: start 5501.830000, end 5727.931000 Metadata: title : Chapter 25 Chapter #0:25: start 5727.931000, end 5866.694000 Metadata: title : Chapter 26 Chapter #0:26: start 5866.694000, end 6109.312000 Metadata: title : Chapter 27 Chapter #0:27: start 6109.312000, end 6340.918000 Metadata: title : Chapter 28 Stream #0:0: Video: h264 (Main), yuv420p(tv, bt709, progressive), 1920x1040 [SAR 1:1 DAR 24:13], 23.98 fps, 23.98 tbr, 1k tbn, 180k tbc (default) Metadata: DURATION : 01:45:40.981000000 Stream #0:1(eng): Audio: aac (LC), 48000 Hz, stereo, fltp (default) Metadata: title : Stereo DURATION : 01:45:41.013000000 Stream #0:2(eng): Subtitle: hdmv_pgs_subtitle Metadata: DURATION : 01:44:52.954000000 Please use -profile:a or -profile:v, -profile is ambiguous Stream mapping: Stream #0:0 (h264) -> scale scale -> Stream #0:0 (libx264) Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help [libx264 @ 000002785e3c2b00] using SAR=1/1 [libx264 @ 000002785e3c2b00] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 [libx264 @ 000002785e3c2b00] profile Main, level 4.1, 4:2:0, 8-bit [libx264 @ 000002785e3c2b00] 264 - core 157 r2935 545de2f - H.264/MPEG-4 AVC codec - Copyleft 2003-2018 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x1:0 me=dia subme=0 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=4 chroma_me=0 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=24 lookahead_threads=4 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=23 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=20108 vbv_bufsize=40216 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.00 [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05326.ts' for writing Output #0, segment, to 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05%d.ts': Metadata: encoder : Lavf58.12.100 Stream #0:0: Video: h264 (libx264), yuv420p, 1920x1040 [SAR 1:1 DAR 24:13], q=-1--1, 23.98 fps, 90k tbn, 23.98 tbc (default) Metadata: encoder : Lavc58.18.100 libx264 Side data: cpb: bitrate max/min/avg: 20108000/0/0 buffer size: 40216000 vbv_delay: -1 Stream #0:1(eng): Audio: aac (LC), 48000 Hz, stereo, fltp (default) frame= 98 fps=0.0 q=28.0 size=N/A time=00:16:22.72 bitrate=N/A speed=1.96e+03x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05327.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05328.ts' for writing frame= 241 fps=240 q=28.0 size=N/A time=00:16:28.69 bitrate=N/A speed= 983x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05329.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05330.ts' for writing frame= 382 fps=253 q=28.0 size=N/A time=00:16:34.56 bitrate=N/A speed= 660x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05331.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05332.ts' for writing frame= 529 fps=263 q=28.0 size=N/A time=00:16:40.70 bitrate=N/A speed= 498x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05333.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05334.ts' for writing frame= 675 fps=269 q=28.0 size=N/A time=00:16:46.78 bitrate=N/A speed= 401x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05335.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05336.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05337.ts' for writing frame= 831 fps=276 q=28.0 size=N/A time=00:16:53.29 bitrate=N/A speed= 336x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05338.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05339.ts' for writing frame= 983 fps=280 q=28.0 size=N/A time=00:16:59.62 bitrate=N/A speed= 290x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05340.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05341.ts' for writing frame= 1137 fps=283 q=28.0 size=N/A time=00:17:06.04 bitrate=N/A speed= 256x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05342.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05343.ts' for writing frame= 1283 fps=284 q=28.0 size=N/A time=00:17:12.14 bitrate=N/A speed= 229x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05344.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05345.ts' for writing frame= 1417 fps=282 q=28.0 size=N/A time=00:17:17.73 bitrate=N/A speed= 207x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05346.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05347.ts' for writing frame= 1567 fps=284 q=28.0 size=N/A time=00:17:23.98 bitrate=N/A speed= 189x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05348.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05349.ts' for writing frame= 1717 fps=285 q=28.0 size=N/A time=00:17:30.24 bitrate=N/A speed= 174x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05350.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05351.ts' for writing frame= 1865 fps=286 q=28.0 size=N/A time=00:17:36.42 bitrate=N/A speed= 162x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05352.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05353.ts' for writing frame= 2013 fps=286 q=28.0 size=N/A time=00:17:42.59 bitrate=N/A speed= 151x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05354.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05355.ts' for writing frame= 2154 fps=286 q=25.0 size=N/A time=00:17:48.48 bitrate=N/A speed= 142x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05356.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05357.ts' for writing frame= 2296 fps=286 q=28.0 size=N/A time=00:17:54.38 bitrate=N/A speed= 134x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05358.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05359.ts' for writing frame= 2443 fps=286 q=28.0 size=N/A time=00:18:00.53 bitrate=N/A speed= 127x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05360.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05361.ts' for writing frame= 2588 fps=286 q=28.0 size=N/A time=00:18:06.57 bitrate=N/A speed= 120x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05362.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05363.ts' for writing frame= 2728 fps=286 q=28.0 size=N/A time=00:18:12.41 bitrate=N/A speed= 115x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05364.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05365.ts' for writing frame= 2862 fps=285 q=28.0 size=N/A time=00:18:18.00 bitrate=N/A speed= 109x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05366.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05367.ts' for writing frame= 3005 fps=285 q=28.0 size=N/A time=00:18:23.95 bitrate=N/A speed= 105x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05368.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05369.ts' for writing frame= 3147 fps=285 q=28.0 size=N/A time=00:18:29.88 bitrate=N/A speed=100x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05370.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05371.ts' for writing frame= 3297 fps=286 q=28.0 size=N/A time=00:18:36.13 bitrate=N/A speed=96.7x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05372.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05373.ts' for writing frame= 3440 fps=286 q=28.0 size=N/A time=00:18:42.11 bitrate=N/A speed=93.1x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05374.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05375.ts' for writing frame= 3581 fps=285 q=28.0 size=N/A time=00:18:48.00 bitrate=N/A speed=89.9x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05376.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05377.ts' for writing frame= 3721 fps=285 q=28.0 size=N/A time=00:18:53.82 bitrate=N/A speed=86.9x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05378.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05379.ts' for writing frame= 3863 fps=285 q=28.0 size=N/A time=00:18:59.75 bitrate=N/A speed=84.1x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05380.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05381.ts' for writing frame= 3999 fps=284 q=28.0 size=N/A time=00:19:05.42 bitrate=N/A speed=81.5x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05382.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05383.ts' for writing frame= 4149 fps=285 q=28.0 size=N/A time=00:19:11.68 bitrate=N/A speed=79.1x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05384.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05385.ts' for writing frame= 4293 fps=285 q=28.0 size=N/A time=00:19:17.69 bitrate=N/A speed=76.8x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05386.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05387.ts' for writing frame= 4448 fps=286 q=28.0 size=N/A time=00:19:24.18 bitrate=N/A speed=74.8x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05388.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05389.ts' for writing frame= 4598 fps=286 q=28.0 size=N/A time=00:19:30.41 bitrate=N/A speed=72.8x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05390.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05391.ts' for writing frame= 4753 fps=287 q=28.0 size=N/A time=00:19:36.87 bitrate=N/A speed= 71x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05392.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05393.ts' for writing frame= 4908 fps=287 q=28.0 size=N/A time=00:19:43.33 bitrate=N/A speed=69.3x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05394.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05395.ts' for writing frame= 5046 fps=287 q=28.0 size=N/A time=00:19:49.09 bitrate=N/A speed=67.7x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05396.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05397.ts' for writing frame= 5202 fps=288 q=28.0 size=N/A time=00:19:55.60 bitrate=N/A speed=66.1x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05398.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05399.ts' for writing frame= 5344 fps=288 q=25.0 size=N/A time=00:20:01.51 bitrate=N/A speed=64.7x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05400.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05401.ts' for writing frame= 5498 fps=288 q=28.0 size=N/A time=00:20:07.93 bitrate=N/A speed=63.3x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05402.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05403.ts' for writing frame= 5650 fps=288 q=28.0 size=N/A time=00:20:14.29 bitrate=N/A speed= 62x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05404.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05405.ts' for writing frame= 5797 fps=289 q=28.0 size=N/A time=00:20:20.41 bitrate=N/A speed=60.8x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05406.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05407.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05408.ts' for writing frame= 5949 fps=289 q=28.0 size=N/A time=00:20:26.75 bitrate=N/A speed=59.6x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05409.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05410.ts' for writing frame= 6097 fps=289 q=28.0 size=N/A time=00:20:32.93 bitrate=N/A speed=58.5x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05411.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05412.ts' for writing frame= 6247 fps=289 q=28.0 size=N/A time=00:20:39.18 bitrate=N/A speed=57.4x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05413.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05414.ts' for writing frame= 6389 fps=289 q=28.0 size=N/A time=00:20:45.09 bitrate=N/A speed=56.4x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05415.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05416.ts' for writing frame= 6541 fps=289 q=28.0 size=N/A time=00:20:51.45 bitrate=N/A speed=55.4x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05417.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05418.ts' for writing frame= 6695 fps=290 q=28.0 size=N/A time=00:20:57.87 bitrate=N/A speed=54.5x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05419.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05420.ts' for writing frame= 6849 fps=290 q=28.0 size=N/A time=00:21:04.29 bitrate=N/A speed=53.5x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05421.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05422.ts' for writing frame= 7004 fps=290 q=28.0 size=N/A time=00:21:10.76 bitrate=N/A speed=52.7x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05423.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05424.ts' for writing frame= 7161 fps=291 q=28.0 size=N/A time=00:21:17.31 bitrate=N/A speed=51.9x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05425.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05426.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05427.ts' for writing frame= 7311 fps=291 q=28.0 size=N/A time=00:21:23.56 bitrate=N/A speed=51.1x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05428.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05429.ts' for writing frame= 7466 fps=291 q=28.0 size=N/A time=00:21:30.02 bitrate=N/A speed=50.4x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05430.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05431.ts' for writing frame= 7617 fps=292 q=28.0 size=N/A time=00:21:36.32 bitrate=N/A speed=49.6x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05432.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05433.ts' for writing frame= 7766 fps=292 q=28.0 size=N/A time=00:21:42.54 bitrate=N/A speed=48.9x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05434.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05435.ts' for writing frame= 7910 fps=292 q=28.0 size=N/A time=00:21:48.54 bitrate=N/A speed=48.2x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05436.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05437.ts' for writing frame= 8065 fps=292 q=28.0 size=N/A time=00:21:55.00 bitrate=N/A speed=47.6x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05438.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05439.ts' for writing frame= 8214 fps=292 q=28.0 size=N/A time=00:22:01.21 bitrate=N/A speed= 47x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05440.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05441.ts' for writing frame= 8365 fps=292 q=28.0 size=N/A time=00:22:07.53 bitrate=N/A speed=46.4x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05442.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05443.ts' for writing frame= 8512 fps=292 q=25.0 size=N/A time=00:22:13.65 bitrate=N/A speed=45.8x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05444.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05445.ts' for writing frame= 8669 fps=293 q=28.0 size=N/A time=00:22:20.20 bitrate=N/A speed=45.2x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05446.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05447.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05448.ts' for writing frame= 8823 fps=293 q=28.0 size=N/A time=00:22:26.62 bitrate=N/A speed=44.7x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05449.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05450.ts' for writing frame= 8982 fps=293 q=28.0 size=N/A time=00:22:33.25 bitrate=N/A speed=44.2x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05451.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05452.ts' for writing frame= 9142 fps=294 q=28.0 size=N/A time=00:22:39.93 bitrate=N/A speed=43.7x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05453.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05454.ts' for writing frame= 9301 fps=294 q=28.0 size=N/A time=00:22:46.57 bitrate=N/A speed=43.2x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05455.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05456.ts' for writing frame= 9460 fps=294 q=28.0 size=N/A time=00:22:53.18 bitrate=N/A speed=42.7x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05457.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05458.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05459.ts' for writing frame= 9618 fps=295 q=28.0 size=N/A time=00:22:59.77 bitrate=N/A speed=42.3x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05460.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05461.ts' for writing frame= 9780 fps=295 q=28.0 size=N/A time=00:23:06.53 bitrate=N/A speed=41.8x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05462.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05463.ts' for writing frame= 9921 fps=295 q=28.0 size=N/A time=00:23:12.42 bitrate=N/A speed=41.4x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05464.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05465.ts' for writing frame=10065 fps=295 q=28.0 size=N/A time=00:23:18.42 bitrate=N/A speed=40.9x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05466.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05467.ts' for writing frame=10214 fps=295 q=28.0 size=N/A time=00:23:24.65 bitrate=N/A speed=40.5x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05468.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05469.ts' for writing frame=10362 fps=295 q=25.0 size=N/A time=00:23:30.81 bitrate=N/A speed=40.1x [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05470.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05471.ts' for writing [segment @ 000002785e3cc140] Opening 'C:\Users\name\AppData\Roaming\Emby-Server\programdata\transcoding-temp\e6f3098a763f578d4ecc9a07df62ed05.m3u8.tmp' for writing frame=10451 fps=295 q=-1.0 Lsize=N/A time=00:23:34.50 bitrate=N/A speed=39.9x video:306081kB audio:8652kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown [libx264 @ 000002785e3c2b00] frame I:196 Avg QP:20.70 size:121189 [libx264 @ 000002785e3c2b00] frame P:2733 Avg QP:23.90 size: 50561 [libx264 @ 000002785e3c2b00] frame B:7522 Avg QP:25.61 size: 20140 [libx264 @ 000002785e3c2b00] consecutive B-frames: 2.9% 1.6% 4.9% 90.6% [libx264 @ 000002785e3c2b00] mb I I16..4: 42.5% 0.0% 57.5% [libx264 @ 000002785e3c2b00] mb P I16..4: 31.0% 0.0% 0.0% P16..4: 50.8% 0.0% 0.0% 0.0% 0.0% skip:18.2% [libx264 @ 000002785e3c2b00] mb B I16..4: 6.8% 0.0% 0.0% B16..8: 29.9% 0.0% 0.0% direct:18.8% skip:44.6% L0:37.6% L1:44.3% BI:18.1% [libx264 @ 000002785e3c2b00] coded y,uvDC,uvAC intra: 61.1% 0.2% 0.0% inter: 24.1% 0.0% 0.0% [libx264 @ 000002785e3c2b00] i16 v,h,dc,p: 31% 17% 35% 17% [libx264 @ 000002785e3c2b00] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 23% 15% 13% 9% 9% 9% 7% 8% 8% [libx264 @ 000002785e3c2b00] i8c dc,h,v,p: 100% 0% 0% 0% [libx264 @ 000002785e3c2b00] Weighted P-Frames: Y:11.1% UV:1.2% [libx264 @ 000002785e3c2b00] kb/s:5752.35
Luke 42242 Posted February 16, 2019 Posted February 16, 2019 Are you sure the black bars aren't baked into the video?
Blatherscribe 5 Posted February 16, 2019 Author Posted February 16, 2019 I don't think they are. The thing is, they SHOULD appear, but aren't. The video it's expanded until it fills the screen, which I do not want (and I've checked my TV settings, it's not that). If it's the Roku at fault, I can accept that and move on. And I appreciate your willingness to help me figure out a relatively minor frustration.
speechles 2062 Posted February 16, 2019 Posted February 16, 2019 encoder : Lavf58.12.100Stream #0:0: Video: h264 (libx264), yuv420p, 1920x1040 [sAR 1:1 DAR 24:13], q=-1--1, 23.98 fps, 90k tbn, 23.98 tbc (default) Not sure I understand. It is encoding the video into 1920x1040 with an aspect ratio of 1.84615384615 which for all intents and purposes is 1.85. Please make sure to use the Emby Beta version of the Roku app. We may have already fixed this issue in Beta. What Model # is your Roku device? Also what firmware is the device running? Is your Roku display type in the Roku settings set to 1080p?
Blatherscribe 5 Posted February 16, 2019 Author Posted February 16, 2019 This is why I don't understand why it's zoomed-in -- it SHOULD be playing at 1920x1040. I have a Roku 3, automatic updates are on, and it is set to 1080p. Same issue in Emby Beta. It's all right. I suppose I'm only losing a tiny bit of the picture on either end of the screen. Nothing to tear out my hair over. And Emby understands that sometimes I need subtitles and sometimes I don't, so it wins over Plex regardless. Thank you for helping! I'm still willing to try any suggestions, but if it's time to give up and chalk this up to Roku being weird, that's fine too.
speechles 2062 Posted February 16, 2019 Posted February 16, 2019 ...but if it's time to give up and chalk this up to Roku being weird, that's fine too. We never give up. Does your TV have normal, stretch, wide and zoom for screen settings that could cause this? Is there a sample video you have that you can upload somewhere so we can see if we can reproduce this on our Roku devices? Upload to dropbox, google drive, etc.. anywhere and share the link with us of that file. There must either be something wrong with the Roku or something wrong with the file.
Blatherscribe 5 Posted February 16, 2019 Author Posted February 16, 2019 Thanks The TV does have these settings, but it's just on standard 16:9, no zooming. When I play a 4:3 video, it shows up with black bars on the sides. I think the suggestion earlier in this thread was probably spot on, that it's a Roku problem, not an Emby problem. Because every 4:3 video I have plays properly, but every widescreen movie gets zoomed in to fill the TV. After all, Emby displays it correctly in the web app.
speechles 2062 Posted February 16, 2019 Posted February 16, 2019 Reference: Issue #236: Aspect ratio issue / 1.85 zooms to 16:9 If it is an issue it goes on the tracker. Until we figure out the cause and an appropriate response. There is no give up. There is move on but there is always time to come back to this. It is on our tracker and we will investigate. Thanks for spotting an issue.
dbkyle 0 Posted April 24, 2019 Posted April 24, 2019 Ok, glad I found this. It's happening to me as well. Frustrating. 1) Background / Set Up: I am still rocking (with issues), an old kind of setup: Cable-->SD HR Prime -->Old PC/Win7/WMC/Emby --> Xbox360--> "LG 40-something TV" *Mainly because the WAF (Wife Acceptance Factor) on new TV tech is high and even small changes upset her. 2) But as part finally looking at upgrading, I am trying to first get a successful test on this set up: Cable-->SD HR Prime -->PC/Emby(no WMC)--> Roku 3-->TV *Was hoping to get a successful Proof of Concept on existing platform before I either clean install a new OS or just get brand new hardware (have had eye on a new new mini pc back end and a new front end Nvidia Shield) But no success.. I get the lack of zooming issue described above. Rather frustrating really, since the Xbox took care of zooming.. and I never had to think about it. Also other video feeds from Roku (Amazon, Netflix, Hulu Live TV, etc) don't have this lack of zooming issue. Again they just took care of it. No problems seeing content thru web browser or mobile device either So would it be fair to say it's isolated to the Roku or Roku App? If that's the case, does it make sense to get a newer Roku or a Shield? Thanks -D
Luke 42242 Posted April 28, 2019 Posted April 28, 2019 Ok, glad I found this. It's happening to me as well. Frustrating. 1) Background / Set Up: I am still rocking (with issues), an old kind of setup: Cable-->SD HR Prime -->Old PC/Win7/WMC/Emby --> Xbox360--> "LG 40-something TV" *Mainly because the WAF (Wife Acceptance Factor) on new TV tech is high and even small changes upset her. 2) But as part finally looking at upgrading, I am trying to first get a successful test on this set up: Cable-->SD HR Prime -->PC/Emby(no WMC)--> Roku 3-->TV *Was hoping to get a successful Proof of Concept on existing platform before I either clean install a new OS or just get brand new hardware (have had eye on a new new mini pc back end and a new front end Nvidia Shield) But no success.. I get the lack of zooming issue described above. Rather frustrating really, since the Xbox took care of zooming.. and I never had to think about it. Also other video feeds from Roku (Amazon, Netflix, Hulu Live TV, etc) don't have this lack of zooming issue. Again they just took care of it. No problems seeing content thru web browser or mobile device either So would it be fair to say it's isolated to the Roku or Roku App? If that's the case, does it make sense to get a newer Roku or a Shield? Thanks -D @@dbkyle, can we please look at an example? Can we look at the server and ffmpeg log? Thanks !
speechles 2062 Posted April 28, 2019 Posted April 28, 2019 (edited) Rather frustrating really, since the Xbox took care of zooming.. and I never had to think about it. Also other video feeds from Roku (Amazon, Netflix, Hulu Live TV, etc) don't have this lack of zooming issue. Again they just took care of it. No problems seeing content thru web browser or mobile device either So would it be fair to say it's isolated to the Roku or Roku App? If that's the case, does it make sense to get a newer Roku or a Shield? Thanks -D Zooming? Do you mean removing the letterbox? The black surrounding the video layer? You want that zoomed/stretched to fill the screen? You realize this will remove part of the video from your view? The Roku doesn't do this zooming because it allows native downscale. It is hard to offer both zoom and downscale on a device. Your TV itself should offer these in the aspect ratio: Wide, Zoom, Normal, Stretch. Does your TV not allow this? Say the item is 1.85 and you want to force it to 1.77 (16x9) with zoom. You will lose approximtely 172 pixels (1080p) possibly on both sides of the video frames in order to zoom this item. If you stretch this item all the people in the frames will look shorter and fatter. I call this "Oompa Loompa" mode. Some broadcast TV stretch 4x3 to 16x9 and produce their streams in "Oompa Loompa" mode for some reason. I never use that mode unless I want it "For the Lulz!". Wide will correct 4x3 into a proper presentation and remove some of the top/bottom of the video frames. Those other apps don't have this zooming issue because they can curate their items and just those items. With Emby we do not curate your collection of items. You curate them. We get items that are not specially crafted for Roku. Your items may need to transcode to play on the Roku. Those other apps curate their items specifically encoded to play best on Roku. They play their media their way. We play your media your way. There is a huge difference. Edited April 28, 2019 by speechles
dbkyle 0 Posted May 4, 2019 Posted May 4, 2019 @@Luke, @@speechles .Thank you for your assistance and expertise The lack of downscale support, as you described, seems like as good a reason as any to me, for why I am running into my issues. I won't pretend to know anything or be anything other than a fumbling fool. I did manage to confirm this same behavior on both my Roku3 and on a RokuUltra (on off chance it might pass muster).. so passing for now on Roku as a consumption unit for my living room. I picked up a shield box and see it as a single replacement for roku / xbox 360. Still getting a display issue with blank frame space. But software now has vertical/horizonal zoom options to mitigate, even if ut stretch the image weirdly. I hate to say it, but it's feeling like this may just be my stingy old hardware. For example, my LG TV is getting a little long in tooth (8 year old 55" 1080p LCD ). It has built in options for 16:9 / 4:3 / Zoom (@1080p). But adjusting these settings doesn't change anything noticeably. Still a mystery to me, why the old WMC/Xbox Extender live TV "just filled in" so well on it. So at this point, I am focusing on idea that problem/solution is in the painfully old hosting Emby pc box. Working on next cheapest option of just doing a clean install and going from there.
Luke 42242 Posted May 5, 2019 Posted May 5, 2019 Thanks The TV does have these settings, but it's just on standard 16:9, no zooming. When I play a 4:3 video, it shows up with black bars on the sides. I think the suggestion earlier in this thread was probably spot on, that it's a Roku problem, not an Emby problem. Because every 4:3 video I have plays properly, but every widescreen movie gets zoomed in to fill the TV. After all, Emby displays it correctly in the web app. Does it have an automatic option?
dbkyle 0 Posted May 12, 2019 Posted May 12, 2019 (edited) Hi @@Luke, The LG TV does have an "auto" option. But enabling doesn't change things appreciatively. That's usually my default setting anyway. I have admitted defeat on that front. I just chalk the lack of a fully dynamic image to some interaction of older TV tech and the lack of image downshifting/curating. I am leaving it at that. I don't understand all the complications, but it does make sense to me that it's a highly custom function/combination that is just no longer supportable. While testing rebuilt back end (WIn7/WMC now Lumbuntu), I had noticed that I received many duplicated HD versions of my cable channels. I can solve for this, for now, by focusing on "HD" cable channels where the problem doesn't manifest. I am satisfied; Those HD channels act fantastic w/ minimal tuning lag after rebuilding server, both on my new Shield and the older Roku3. (PS: that old window box still had elements of the original Media Browser software on it back when I had first started up a home dvr/media HTPC) My untrained eye / lazy habits had just gotten used to the media extender working with those lower quality streams. Everything changes. -dbk Edited May 12, 2019 by dbkyle
speechles 2062 Posted May 13, 2019 Posted May 13, 2019 (edited) @@dbkyle I am curious. If this happens with just LiveTV there may be something we can do here. It might be as simple as always transcode anything not 720p or 1080p when playing LiveTV. That might seriously be how simple the fix is. Then just restrict this "fix" to only the problem devices(such as your Roku 3) and B I N G O. We have a solution. This could also be automated(no settings required) where it is just like magic. We like magic. Magic makes it feel like it just works. Just working is what we want. Where you just press play and we handle every single thing. Sorry this isn't already happening. Does this problem with SD only happen with LiveTV? Or is it happening with your recordings too? Edited May 13, 2019 by speechles
dbkyle 0 Posted May 23, 2019 Posted May 23, 2019 It might be as simple as always transcode anything not 720p or 1080p when playing LiveTV. That might seriously be how simple the fix is. @@speechles I had tried manually playing with trans coding options before. I don't remember seeing much of a change. However, I don't know how systematic I was with that. I will put on my wizard's cap and have at it again. The wife likes it too when things "just happen by magic"..... she doesn't want to know about the smoke and mirrors or the sacrifices at midnight..
speechles 2062 Posted May 23, 2019 Posted May 23, 2019 (edited) @@speechles I had tried manually playing with trans coding options before. I don't remember seeing much of a change. However, I don't know how systematic I was with that. I will put on my wizard's cap and have at it again. The wife likes it too when things "just happen by magic"..... she doesn't want to know about the smoke and mirrors or the sacrifices at midnight.. According to Roku the 9.1 firmware update solves this problem. If/when it does we will remove this work-around we are doing. We just need confirmation from users that it no longer is causing aspect-ratio issues.. See this post: https://forums.roku.com/viewtopic.php?f=28&t=117793 In that thread users claim firmware version 9.1.x solves the problem. We need confirmation of that then we will restrict our work-around to pre 9.1 at that time. ^_~ You can message RokuTannerD on Roku forums and describe your problem with aspect ratio on your Roku 3 and that you would like the 9.1 firmware on your Roku. Provide him your serial number from your Roku device. That should put you on the list to receive 9.1 immediately. Once approved you will just need to check for updates to get the new firmware. Edited May 23, 2019 by speechles
