Auto-organize not working
fusrodah26
Hey guys.
The last couple days, auto-organize has not been working for me. It hasn't moved any episodes into their folders, and doesn't work when I try to do it manually from the auto-organize screen either.
I recently changed the drive mapping for the library to the network rather than through Windows, and that seems to be when the problem started. I've done a complete uninstall with no luck as well.
Thoughts?
Koleckai Silvestri
You should use UNC paths for your library. Drive mapping doesn't always work.
bluemonkey07
Hey guys.
Thoughts?
You may have a share permission issue then ie you don't have write permission to the UNC share Edited by Vidman
bluemonkey07
I believe that's what he is trying to say that he did
