kelinger 0 Posted February 14, 2019 Posted February 14, 2019 For the past couple months, Trakt hasn't been working for me. The console would show errors syncing (to and from). I thought this occurred after the 4.x upgrade but I see other posts from people mentioning Trakt so now I think the problem is just me. I recently uninstalled Trakt completely, restarted, and then successfully installed it. However, when I go to configure it, the "Configure Trakt for" dropdown is empty and putting in a pin and saving just clears the screen and any options I've checked. Honestly, I haven't played with its settings in years so I'm not sure what "should" happen. However, I do know that right now, nothing is updating in either direction. For what its worth: This is running in Docker using the emby/embyserver distribution. Docker and Emby are up-to-date, as is the Trakt plugin 3.3.0.0. Ken
Luke 42255 Posted February 14, 2019 Posted February 14, 2019 Hi there, trakt works just fine. Please see how to report a problem. Thanks ! @@J2ghz
kelinger 0 Posted February 14, 2019 Author Posted February 14, 2019 Thanks, Luke, for the near-instant response. There really isn't much to add from the log files. Trakt-related messages below; full log attached 2019-02-14 15:13:30.092 Info App: Loading Trakt, Version=3.3.0.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Trakt.dll 2019-02-14 15:13:32.460 Info App: Starting entry point Trakt.ServerMediator 2019-02-14 15:13:32.461 Info App: Entry point completed: Trakt.ServerMediator. Duration: 0.0009563 seconds 2019-02-14 15:13:34.918 Info TaskManager: StartupTrigger fired for task: Import playstates from Trakt.tv 2019-02-14 15:13:34.919 Info TaskManager: Queueing task SyncFromTraktTask 2019-02-14 15:13:34.922 Info TaskManager: Executing Import playstates from Trakt.tv 2019-02-14 15:13:34.927 Info Trakt: No Users returned 2019-02-14 15:13:34.928 Info TaskManager: Import playstates from Trakt.tv Completed after 0 minute(s) and 0 seconds 2019-02-14 15:17:50.425 Info TaskManager: IntervalTrigger fired for task: Sync library to trakt.tv 2019-02-14 15:17:50.425 Info TaskManager: Executing Sync library to trakt.tv 2019-02-14 15:17:50.429 Info Trakt: No Users returned 2019-02-14 15:17:50.429 Info TaskManager: Sync library to trakt.tv Completed after 0 minute(s) and 0 seconds embyserver.txt
Luke 42255 Posted February 14, 2019 Posted February 14, 2019 Can you try it from the web app on the local machine?
kelinger 0 Posted February 14, 2019 Author Posted February 14, 2019 The machine (server) itself is headless; however, accessing it from the web locally (Chrome / Macintosh) just shows this screen. There's no dropdown for the first item and entering other data and checking boxes followed by "save" simply return to the screen below as well. From what I can tell, no errors are generated in the log when this happens.
Luke 42255 Posted February 15, 2019 Posted February 15, 2019 Can you capture the browser debug console output? thanks.
