jpichie 7 Posted February 14, 2019 Posted February 14, 2019 Good afternoon, I have been having issues with emby since Version 4 by the looks of it. I have had the same issue on Kodi 17.6 - 18 RC - 18 Stable with Emby for Kodi. When I first install Emby for Kodi, it goes through the prompts, I connect to my server, enable artwork caching, whole tomatoes, etc. I sync my TV and Movies. When I check my Emby settings, they look correct, Companion is enabled, artwork caching is enabled, I hit OK and close out. When I open up Kodi again, I get prompted to enable artwork caching and to turn on Companion. This happens EVERYTIME, and these settings get disabled again after I restart Kodi (or they never get enabled). Any help would be appreciated. This has happened exactly the same way on 4 separate systems, 3 of which were fresh installs. kodi.log
Solution Angelblue05 4132 Posted February 14, 2019 Solution Posted February 14, 2019 https://github.com/MediaBrowser/plugin.video.emby/wiki/kodi-companion 1
jpichie 7 Posted February 14, 2019 Author Posted February 14, 2019 OH... MY... GOD... Why is this a plugin in Emby 4? Thanks Angelblue
Angelblue05 4132 Posted February 14, 2019 Posted February 14, 2019 (edited) It's always been a server plugin. What changed is, if you didn't have the server plugin installed. Then it would do a long manual sync at start up. That is now gone and was replace with manually update your libraries instead (launch emby for kodi > manage libraries or https://github.com/MediaBrowser/plugin.video.emby/wiki/tips#context-menu-for-libraries ). Edited February 14, 2019 by Angelblue05
