bmmjtrip 0 Posted February 13, 2019 Posted February 13, 2019 ok so i installed Emby and after some trouble got it working perfectly. it's been working great for a few weeks then i went to add some shows and movies and the images wouldn't update? i tried to search and identify and won't find anything? any help would be great
Happy2Play 9811 Posted February 13, 2019 Posted February 13, 2019 Can you post your server log.How to Report a Problem
bmmjtrip 0 Posted February 13, 2019 Author Posted February 13, 2019 little new to Emby i was a long time PLEX user so trying to get hang of this Log.txt
Happy2Play 9811 Posted February 13, 2019 Posted February 13, 2019 Looks like a connectivity issues as almost all your requests are timing out.
Luke 42237 Posted February 13, 2019 Posted February 13, 2019 Yes that is correct. All outgoing communications are failing. Do you have some configuration on your NAS that might be preventing Emby Server from accessing the internet?
bmmjtrip 0 Posted February 15, 2019 Author Posted February 15, 2019 ok well i didn't change a single setting and now everything works fine again?
