Huede82 1 Posted February 12, 2019 Posted February 12, 2019 Hi To use emby on an old TV I bought the amazon fire TV Stick. The installation of the emby app was no problem, also the server in the home network was found without any problems. Login with my user was also no problem. BUT on the next start, I have to enter again my password, why? Do I miss the store login details button? Thanks
kikinjo 294 Posted February 12, 2019 Posted February 12, 2019 Check app options, turn login as current user option and password will be saved.
Huede82 1 Posted February 12, 2019 Author Posted February 12, 2019 I'll look, when I am back home. You are talking about the options from the App in the Home screen of the Fire stick, ora options IN the app?
ebr 16337 Posted February 12, 2019 Posted February 12, 2019 Hi. This app is assumed to be used on a shared device so we don't turn that option on by default but you can configure it. Thanks.
Huede82 1 Posted February 13, 2019 Author Posted February 13, 2019 Thanks, with your informatons i found the option to activate this. have a nice day
