KumarjitDey 103 Posted February 12, 2019 Posted February 12, 2019 Could there be an option to rename these tracks to say "English" or "Spanish" 1
ginjaninja 605 Posted February 12, 2019 Posted February 12, 2019 Could there be an option to rename these tracks to say "English" or "Spanish" in the mean time are you aware you can identify properly in the underlying filesystem eg use mkvtoolnix to allocate language on mkv tracks or add country code to external subtitle files..i assume tools exist for other file formats. this would be more robust in any case. Sent from my SM-G955F using Tapatalk
Luke 42246 Posted February 12, 2019 Posted February 12, 2019 It's possible, yes, but it would be better to update your files. Why? because when we direct play sometimes we get track information directly from the video player.
KumarjitDey 103 Posted February 13, 2019 Author Posted February 13, 2019 It's possible, yes, but it would be better to update your files. Why? because when we direct play sometimes we get track information directly from the video player. okay. Can You please recommend me some free softwares with which I can update the audio track names for mp4, mkv files
Deathsquirrel 745 Posted February 13, 2019 Posted February 13, 2019 okay. Can You please recommend me some free softwares with which I can update the audio track names for mp4, mkv files MKVToolnix does this.
KumarjitDey 103 Posted February 13, 2019 Author Posted February 13, 2019 MKVToolnix does this. thank you
KumarjitDey 103 Posted February 13, 2019 Author Posted February 13, 2019 does the conversion take a lot of time?
Luke 42246 Posted February 13, 2019 Posted February 13, 2019 I haven't used the tool in a long time so I don't remember. But hopefully it can do this just by updating the headers.
KumarjitDey 103 Posted February 13, 2019 Author Posted February 13, 2019 (edited) Okay I just now used the mkvtoolnix software. The name of the audio got changed successfully from Undetermined to English, but the problem is those other texts "AAC setero default" still appears, when I don't want them to. I want the name of the audio to be, simply, "English", which doesn't seem possible. So you see, if there was a built-in feature in Emby that could allow to change audio name, it would be very helpful. Edited February 13, 2019 by KumarjitDey
KumarjitDey 103 Posted February 13, 2019 Author Posted February 13, 2019 You're welcome. Hopefully, I will see an option to change the audio name in a future update
ginjaninja 605 Posted February 13, 2019 Posted February 13, 2019 does the conversion take a lot of time? i think there are two ways of doing this, one is to remux the entire file (long time) - as per your screenshot, the other is to use one of the sub tools which just changes the tags (i think), but i forget what that sub tool is called. the commandline tool is https://mkvtoolnix.download/doc/mkvpropedit.html every audio track has codec and channels 'technical data' which probably wont be going away (other users like theses) i guess you are asking for an additional "audio track title" field to be added to the database schema, and when populated, show in preference to the underlying technical data? Could be useful not just for eg "English" but also for eg "Directors Commentary" maybe couched in these terms it broadens the appeal of the feature request if i am barking up the right tree.. found this while searching..has some info on mp4 property edits https://forums.plex.tv/t/renaming-audio-tracks/76531/11
crusher11 1144 Posted February 13, 2019 Posted February 13, 2019 Yes, it would be useful for commentaries or different mixes that are the same layout/codec. Emby used to read that metadata but they disabled the feature for some reason.
Peoria Tom 0 Posted December 21, 2022 Posted December 21, 2022 Re: assigning language conventions to the audio/sub track of a video file with MKV Tooknix....for an ~2Gb size video file, the remux time is about 3 minutes. A 12 Gb sized video takes about 7 minutes to complete. Re: assigning text to the names of audio tracks on movies, I too would love it if the name of the track (as an example "Audio commentary with director Penelope Spheeris") would show up on my Roku in the choices for Audio. I am still open to learning how to see that happen for Emby. Tom
Peoria Tom 0 Posted December 21, 2022 Posted December 21, 2022 Solved On 6/21/2020 at 5:41 PM, RaptorCentauri said: What you are looking for is on the server-side. Library -> Advanced -> Embedded Track Title Display -> Prefer Embedded Titles Dayum, youse gize are guud! Tom
seanbuff 1356 Posted December 21, 2022 Posted December 21, 2022 12 minutes ago, Peoria Tom said: Re: assigning language conventions to the audio/sub track of a video file with MKV Tooknix....for an ~2Gb size video file, the remux time is about 3 minutes. A 12 Gb sized video takes about 7 minutes to complete. FYI - Changing language or the title of a track does not require a remux, only an update of the headers. It should only take seconds using either 'mkvpropedit' or Header editor in the GUI of MKVtoolnix. 2
