Mahlke 0 Posted June 12, 2020 Posted June 12, 2020 When I choose just one Movie folder. Emy shows me all the VTS files. See attached screenshot
Luke 42243 Posted June 16, 2020 Posted June 16, 2020 Did you try running a library scan after updating to Emby Server 4.4.3?
Mahlke 0 Posted June 16, 2020 Posted June 16, 2020 Yes, of course. No success. Maybe This issue is only on the Netgear ReadyNAS system...Should I try it in one of my other servers? Can I use my premium account on another server?
Mahlke 0 Posted September 19, 2020 Posted September 19, 2020 Hello. I have installed the emby server on a Windows 10 PC now. And guess what... Emby is showing all my movies the way it should.
Luke 42243 Posted September 20, 2020 Posted September 20, 2020 Have you considered converting your dvd folder rips to mkv?
Mahlke 0 Posted September 20, 2020 Posted September 20, 2020 Yes of course. But there are 1250 DVD‘s. I haven’t found a software which can handle those all at once. Mac maker and handbrake take a long time.
Luke 42243 Posted September 26, 2020 Posted September 26, 2020 How did you import the library into Synology? Using what folders?
