Luke 42238 Posted July 25, 2020 Posted July 25, 2020 For those interested in trying something new, please try this: Thanks !
Steve0x2a 0 Posted January 7, 2021 Posted January 7, 2021 I cannot enable hardware acceleration, the following is my log file. My motherboard model is j3455, hardware acceleration is used in jellyfin. hardware_detection-63745642855.txt
Luke 42238 Posted January 9, 2021 Posted January 9, 2021 On 1/7/2021 at 6:07 AM, Steve0x2a said: I cannot enable hardware acceleration, the following is my log file. My motherboard model is j3455, hardware acceleration is used in jellyfin. hardware_detection-63745642855.txt 116.2 kB · 0 downloads Hi there, did you follow our hardware acceleration setup guide?
Steve0x2a 0 Posted January 11, 2021 Posted January 11, 2021 On 1/9/2021 at 12:17 PM, Luke said: Hi there, did you follow our hardware acceleration setup guide? yes I did.
tonywoolf 5 Posted February 20, 2021 Posted February 20, 2021 Same here. I have Intel(R) Core(TM) i5-8500 CPU @ 3.00GHz (Emby Premiere Lifetime as well). No acceleration at all. Your hardware acceleration guide doesn't include synology setup, so I am little bit lost. Do i need any additional driver? If I install nVidia GeForce GTX 1050, do I need to compile any driver? What is the mechanics of hardware recognition in the Emby itself? Can you provide some help, please? Thank You in advance!
Luke 42238 Posted February 20, 2021 Posted February 20, 2021 7 hours ago, tonywoolf said: Same here. I have Intel(R) Core(TM) i5-8500 CPU @ 3.00GHz (Emby Premiere Lifetime as well). No acceleration at all. Your hardware acceleration guide doesn't include synology setup, so I am little bit lost. Do i need any additional driver? If I install nVidia GeForce GTX 1050, do I need to compile any driver? What is the mechanics of hardware recognition in the Emby itself? Can you provide some help, please? Thank You in advance! HI, are you on Xpenology?
tonywoolf 5 Posted February 20, 2021 Posted February 20, 2021 Just now, Luke said: HI, are you on Xpenology? Yes, I am on Xpenology. DS918+ DSM 6.2.3-25426 Update 3 Jun’s Loader v1.04b DS918+
Luke 42238 Posted February 20, 2021 Posted February 20, 2021 32 minutes ago, tonywoolf said: Yes, I am on Xpenology. DS918+ DSM 6.2.3-25426 Update 3 Jun’s Loader v1.04b DS918+ Please attach the emby server and hardware detection log files. thanks.
premikkoci 1 Posted February 20, 2021 Posted February 20, 2021 Did you install custom extra.lzma? Does /dev/dri/ folder exist?
tonywoolf 5 Posted February 20, 2021 Posted February 20, 2021 8 minutes ago, Luke said: Please attach the emby server and hardware detection log files. thanks. embyserver.txt hardware_detection-63749445147.txt
tonywoolf 5 Posted February 20, 2021 Posted February 20, 2021 2 hours ago, premikkoci said: Did you install custom extra.lzma? Does /dev/dri/ folder exist? I did not. /dev/dri/ does't exist.
premikkoci 1 Posted February 20, 2021 Posted February 20, 2021 Then you did not follow instructions. Check https://xpenology.com/forum/topic/28321-driver-extension-jun-103b104b-for-dsm623-for-918-3615xs-3617xs/
kosenkovserj 0 Posted January 2, 2023 Posted January 2, 2023 Not starting hardware transcoding on xpenology 7.1.1 by ds1621+ with amd ryzen 5600g processor hardware_detection-63808288417.txt embyserver-2.txt
Luke 42238 Posted January 19, 2023 Posted January 19, 2023 On 1/2/2023 at 12:41 PM, kosenkovserj said: Not starting hardware transcoding on xpenology 7.1.1 by ds1621+ with amd ryzen 5600g processor hardware_detection-63808288417.txt 135.01 kB · 0 downloads embyserver-2.txt 40.21 kB · 0 downloads HI, what is detected in server transcoding settings?
kosenkovserj 0 Posted January 19, 2023 Posted January 19, 2023 4 hours ago, Luke said: HI, what is detected in server transcoding settings? Hi Nothing:
DDim 0 Posted January 30, 2023 Posted January 30, 2023 Software: Xpenology DSM 7.1.1 Hardware: Asrock J4105-ATX Problem in Emby: Hardware transcoding is too slow – see logs. Where is no such problem in the Video Station. hardware_detection-63810687186.txt ffmpeg-transcode-3f83d9fe-35c4-4ea8-b49b-4ada0c4b5d2e_1.txt
kosenkovserj 0 Posted January 30, 2023 Posted January 30, 2023 with an AMD processor no chance? in synology os no directory /dev/dri
gawihe9643 0 Posted February 23, 2023 Posted February 23, 2023 It seems that the driver was determined, but still chose the software. Worth Xpenology 7.1.1 ffmpeg-transcode-48bc4403-08ca-4153-b629-af4c20156fbb_1.txt
Happy2Play 9811 Posted February 23, 2023 Posted February 23, 2023 50 minutes ago, gawihe9643 said: It seems that the driver was determined, but still chose the software. Worth Xpenology 7.1.1 ffmpeg-transcode-48bc4403-08ca-4153-b629-af4c20156fbb_1.txt 194.2 kB · 0 downloads Do you have Emby Premiere? Warning: Hardware acceleration is not available as it requires a valid Premiere Subscription
gawihe9643 0 Posted February 23, 2023 Posted February 23, 2023 11 minutes ago, Happy2Play said: Do you have Emby Premiere? Is there any conditional test period, 1 day or 1 hour, I want to check if it will work for me with such HW transcoding before buying
Luke 42238 Posted March 24, 2023 Posted March 24, 2023 On 1/30/2023 at 7:27 AM, DDim said: Software: Xpenology DSM 7.1.1 Hardware: Asrock J4105-ATX Problem in Emby: Hardware transcoding is too slow – see logs. Where is no such problem in the Video Station. hardware_detection-63810687186.txt 227.61 kB · 3 downloads ffmpeg-transcode-3f83d9fe-35c4-4ea8-b49b-4ada0c4b5d2e_1.txt 404 kB · 5 downloads @DDim looks like it's due to burning in subtitles, which is going to be a very intensive process even for a powerful machine. How does it compare without subtitles?
zhuzhe 2 Posted June 14, 2024 Posted June 14, 2024 I am using Redpill Recovery loader for Xpenology DSM 7.2 The CPU is i7-1255U with intel iGPU. Emby Premiere key was fiiled but i can't see anything in transcode advanced. Please help, thanks. "DeviceInfo": { "VendorName": "Intel Corporation", "DeviceName": "Alder Lake-UP3 GT2 [UHD Graphics]", "VendorId": 32902, "DeviceId": 17960, "SubsytemVendorId": 0, "SubsytemDeviceId": 0, "DevPath": "/sys/bus/pci/devices/0000:00:02.0", "DrmCard": "/dev/dri/card0", "DrmRender": "/dev/dri/renderD128", "IsEnabled": 1, "IsBootVga": 1, "Error": { "Number": -1, "Message": "Failed to initialize VA /dev/dri/renderD128. Error -1" } hardware_detection-63853933958.txt
Happy2Play 9811 Posted June 14, 2024 Posted June 14, 2024 5 minutes ago, zhuzhe said: I am using Redpill Recovery loader for Xpenology DSM 7.2 The CPU is i7-1255U with intel iGPU. Emby Premiere key was fiiled but i can't see anything in transcode advanced. Please help, thanks. "DeviceInfo": { "VendorName": "Intel Corporation", "DeviceName": "Alder Lake-UP3 GT2 [UHD Graphics]", "VendorId": 32902, "DeviceId": 17960, "SubsytemVendorId": 0, "SubsytemDeviceId": 0, "DevPath": "/sys/bus/pci/devices/0000:00:02.0", "DrmCard": "/dev/dri/card0", "DrmRender": "/dev/dri/renderD128", "IsEnabled": 1, "IsBootVga": 1, "Error": { "Number": -1, "Message": "Failed to initialize VA /dev/dri/renderD128. Error -1" } hardware_detection-63853933958.txt 138.18 kB · 0 downloads Interesting as all other "Message": "Failed to initialize VA /dev/dri/renderD128. Error -1" topics say this was resolved in 4.8.8.0/4.9.0.23 but appears not for you. Unless this build didn't get the fix but a dev would have to comment on that. @Luke
Luke 42238 Posted June 14, 2024 Posted June 14, 2024 1 hour ago, zhuzhe said: I am using Redpill Recovery loader for Xpenology DSM 7.2 The CPU is i7-1255U with intel iGPU. Emby Premiere key was fiiled but i can't see anything in transcode advanced. Please help, thanks. "DeviceInfo": { "VendorName": "Intel Corporation", "DeviceName": "Alder Lake-UP3 GT2 [UHD Graphics]", "VendorId": 32902, "DeviceId": 17960, "SubsytemVendorId": 0, "SubsytemDeviceId": 0, "DevPath": "/sys/bus/pci/devices/0000:00:02.0", "DrmCard": "/dev/dri/card0", "DrmRender": "/dev/dri/renderD128", "IsEnabled": 1, "IsBootVga": 1, "Error": { "Number": -1, "Message": "Failed to initialize VA /dev/dri/renderD128. Error -1" } hardware_detection-63853933958.txt 138.18 kB · 2 downloads Hi, please attach the main emby server log as well. thanks.
zhuzhe 2 Posted June 14, 2024 Posted June 14, 2024 59 minutes ago, Luke said: Hi, please attach the main emby server log as well. thanks. Sure, Thanks for help hardware_detection-63853962071.txt embyserver.txt
