Sammy 791 Posted February 14, 2019 Author Posted February 14, 2019 I restarted my Emby server and it showed up.. Installed and restarted then ran it with no change in the trailer sort order and it seems it did not run long enough to do anything. Sent from my SM-G960U1 using Tapatalk
Happy2Play 9814 Posted February 14, 2019 Posted February 14, 2019 Try the beta version of timelord movies... it should list a separate task in the scheduler for doing this for trailers. I haven't dug into it but I am not seeing any change? I checked the ones currently appearing in Latest Trailers and none of the dateadded dates have changed?
Sammy 791 Posted February 14, 2019 Author Posted February 14, 2019 I could look at doing this for the timelord movies plugin.. I’ll take a quick look when I get chance.. (tomorrow at the earliest) my day job keeps me super busy, and Being a dad keeps me busy at home.. I’m suspecting this is a bit of a low demand change.BTW, Thanks for not rushing it! LOL, you put it out in less than 24 hours which I consider an extreme rush! It's Valentine's Day. Go enjoy your family! We can certainly wait a bit to try again. Sent from my SM-G960U1 using Tapatalk
Happy2Play 9814 Posted October 21, 2019 Posted October 21, 2019 Try the beta version of timelord movies... it should list a separate task in the scheduler for doing this for trailers. Not that I could see any difference with this task, it can be removed since it was added to the server in 4.3. Fix latest trailers sort order
Sammy 791 Posted October 21, 2019 Author Posted October 21, 2019 I haven't had issues with the beta server but it persists in my production server. Next stable release? Sent from my SM-G960U1 using Tapatalk
