Sammy 791 Posted February 11, 2019 Posted February 11, 2019 I searched and didn't see this covered before although I thought I saw a post about it. My trailer sort order is reverse alphabetical even though I changed it to descending release date. I thought maybe Y-Trailers was the issue so I uninstalled then a Library Scan triggered (May be on a schedule of maybe triggered by uninstalling Y-Trailers) At any rate, the sort order is still not what I expect to see. Emby Server Log 20190211.txt
Luke 42255 Posted February 11, 2019 Posted February 11, 2019 You can't change the sort order on the home screen, it's only for the screen where you charged it.
Sammy 791 Posted February 11, 2019 Author Posted February 11, 2019 You can't change the sort order on the home screen, it's only for the screen where you charged it.I'm sorry, @@Luke I'm not quite understanding what you mean. Thanks! Sent from my SM-G960U1 using Tapatalk
Sammy 791 Posted February 11, 2019 Author Posted February 11, 2019 You can't change the sort order on the home screenSo I set it for Release Date Descending in each folder (Netflix, Blu-Ray, etc) and did a full library scan. It is still by Descending alphabet. I'm not sure where else to make this sort order setting. I'm usually pretty good at figuring stuff out but I'm being dense this time.. Thanks Sent from my SM-G960U1 using Tapatalk
Happy2Play 9814 Posted February 11, 2019 Posted February 11, 2019 And were are you seeing the wrong order? It is not the same page where you set the sort order, correct? Those other pages have there own query (ie Home Screen-Latest Trailers). But there is still something wrong as your Latest Trailers would appear broken to me. Where my Latest Trailers is descending by release date
Sammy 791 Posted February 11, 2019 Author Posted February 11, 2019 (edited) From the home page drilling down..I Don't know of anyplace else to set the sorting? Sent from my SM-G960U1 using Tapatalk Edited February 12, 2019 by Sammy
Happy2Play 9814 Posted February 11, 2019 Posted February 11, 2019 The sorting only applies to that page. I believe Home Screen section have there own queries, independent of those pages. (list.html does not equal home.html)
Sammy 791 Posted February 11, 2019 Author Posted February 11, 2019 So where do I set the sorting for the trailers on the home screen that are in Descending Alphabetical? Sent from my SM-G960U1 using Tapatalk
Happy2Play 9814 Posted February 11, 2019 Posted February 11, 2019 (edited) So where do I set the sorting for the trailers on the home screen that are in Descending Alphabetical? Sent from my SM-G960U1 using Tapatalk You can not set this. To me you have a defect in your installation as it should be doing this by default (release date-descending). What dateadded and releasedate information is shown for those items shown in Latest trailers? Edited February 11, 2019 by Happy2Play
Sammy 791 Posted February 12, 2019 Author Posted February 12, 2019 You can not set this. To me you have a defect in your installation as it should be doing this by default (release date-descending). What dateadded and releasedate information is shown for those items shown in Latest trailers? These must be trailers from Archived Trailers? This is what I see on the Media Information Page for example: There is no DateAdded or ReleaseDate shown. Where else would I look for this information?
Happy2Play 9814 Posted February 12, 2019 Posted February 12, 2019 These must be trailers from Archived Trailers? This is what I see on the Media Information Page for example: Yogi a.PNG Yogi b.PNG There is no DateAdded or ReleaseDate shown. Where else would I look for this information? Click "edit metadata" on the trailer. This makes since now. Did you must just enable Archived Trailers? I just did and now my Latest trailers are all old traiers. Pretty sure everything on the Home Screen is queried by Date Added, all the Archived Trailers have the newest date added.
Sammy 791 Posted February 12, 2019 Author Posted February 12, 2019 Click "edit metadata" on the trailer. This makes since now. Did you must just enable Archived Trailers? I just did and now my Latest trailers are all old traiers. Pretty sure everything on the Home Screen is queried by Date Added, all the Archived Trailers have the newest date added. @@Happy2Play thanks for helping sort this. How to undo it? I did recently check the Archive Trailers check box. Wish I knew this would be the result.. makes sense that the end of the alphabet is first now as those were probably pulled last. @@Luke any way to expose the settings for this or revise the logic? Any way to revert? Thanks! Sent from my SM-G960U1 using Tapatalk
Sammy 791 Posted February 12, 2019 Author Posted February 12, 2019 BTW, Edit Metadata is not an available option. Sent from my SM-G960U1 using Tapatalk
Happy2Play 9814 Posted February 12, 2019 Posted February 12, 2019 What client? It is available in the web client.
Sammy 791 Posted February 12, 2019 Author Posted February 12, 2019 What client? It is available in the web client. Mobile web client Chrome on Android with either mobile or desktop site checked in settings.. I'll try in a browser on my PC when I get home. Sent from my SM-G960U1 using Tapatalk
Happy2Play 9814 Posted February 13, 2019 Posted February 13, 2019 I don't think there is a easy way around this. I opened the database, went to the MediaItems table and filtered type column with "10" for trailers, then went to the Premieredate column and sorted that column and copied all the items with dates and pasted them in the datecreated column. So now all the trailers have Release date for DateAdded.
Sammy 791 Posted February 13, 2019 Author Posted February 13, 2019 Mobile web client Chrome on Android with either mobile or desktop site checked in settings.. I'll try in a browser on my PC when I get home. Sent from my SM-G960U1 using Tapatalk Ran out of time to check last night. I'll try for tonight. I run a beta server on a separate machine but with the same library and on there my trailers are fine. Sent from my SM-G960U1 using Tapatalk
Sammy 791 Posted February 13, 2019 Author Posted February 13, 2019 I don't think there is a easy way around this. I opened the database, went to the MediaItems table and filtered type column with "10" for trailers, then went to the Premieredate column and sorted that column and copied all the items with dates and pasted them in the datecreated column. So now all the trailers have Release date for DateAdded. I'm not afraid to do this in notepad++ if more detailed instructions are provided. Thanks. Sent from my SM-G960U1 using Tapatalk
Happy2Play 9814 Posted February 13, 2019 Posted February 13, 2019 I'm not afraid to do this in notepad++ if more detailed instructions are provided. Thanks. Sent from my SM-G960U1 using Tapatalk Sorry information only reside in the database. So you would need a database browser program like SQLiteDatabaseBrowser. Filter type "10", sort "premieredate" column, select those dates, copy (crtl+c), go to "datecreated" first item and paste (ctrl+v) Ensure you backup your library.db before doing any edits. This is what the TimeLord plugins do, but only applies to Movies and Shows. We could ask @@BeppoMonkeyBoy to add Trailers also. 1
BeppoMonkeyBoy 98 Posted February 13, 2019 Posted February 13, 2019 I could look at doing this for the timelord movies plugin.. I’ll take a quick look when I get chance.. (tomorrow at the earliest) my day job keeps me super busy, and Being a dad keeps me busy at home.. I’m suspecting this is a bit of a low demand change. 2
Sammy 791 Posted February 13, 2019 Author Posted February 13, 2019 Sorry information only reside in the database. So you would need a database browser program like SQLiteDatabaseBrowser. Filter type "10", sort "premieredate" column, select those dates, copy (crtl+c), go to "datecreated" first item and paste (ctrl+v) Ensure you backup your library.db before doing any edits. This is what the TimeLord plugins do, but only applies to Movies and Shows. We could ask @@BeppoMonkeyBoy to add Trailers also. This one? https://sqlitebrowser.org/ Sent from my SM-G960U1 using Tapatalk
Happy2Play 9814 Posted February 13, 2019 Posted February 13, 2019 This one? https://sqlitebrowser.org/ Sent from my SM-G960U1 using Tapatalk That is what I use. 1
BeppoMonkeyBoy 98 Posted February 14, 2019 Posted February 14, 2019 Try the beta version of timelord movies... it should list a separate task in the scheduler for doing this for trailers. 1
Sammy 791 Posted February 14, 2019 Author Posted February 14, 2019 Try the beta version of timelord movies... it should list a separate task in the scheduler for doing this for trailers.I am not seeing a beta version the catalog. The latest version I see is release date 2019 01 07. Does time lord always change the date added to the release date? Is there a way to sort in mb bye release date and by date added after installing Time Lord? I paid for and had timelord installed for a while but I did not like not being able to find recently added titles and me when the release date may have been in years past. Is the license keyed to MV premier or is there another license I need to dig up in an old email? Thank you for incorporating this feature into time Lord by the way. Sent from my SM-G960U1 using Tapatalk
