vaise 340 Posted February 11, 2019 Posted February 11, 2019 (edited) Im new to the native Emby recording option. It is all working fine (using the TVH stream to record from). I am using the IceTV XMLTV guide data (im in Australia). So, some recordings are identified correctly and have the images for them, others seem to have an IceTV supplied image with just the show name. I go into metadata for the TV Show in the Recordings folder using Emby console, Identify them correctly and the images are then there. But when I delete a watched show, the next time it gets recorded, there is no image again. My media files are set to be stored in the same location. Where do I go to make this be remembered for the next time they are recorded ? I have read that this should be supplied by the IceTV guide - I will investigate there. Thanks. Edited February 11, 2019 by vaise
Luke 42244 Posted February 11, 2019 Posted February 11, 2019 if you delete the series and it is completely gone, then you'll have to identify again.
