fraenhawk 61 Posted June 21, 2014 Posted June 21, 2014 I never touched the specials previously other than creating the folder names as "Season 0" so I'm not sure how some of them had different metadata. Leftover from the MB2 to MB3 move perhaps? As I said, I went through all of them and made them all uniform. All of them now have a Season Number of 0, and all of them have a Sort Name of Specials now.
ebr 16334 Posted June 21, 2014 Posted June 21, 2014 I never touched the specials previously other than creating the folder names as "Season 0" so I'm not sure how some of them had different metadata. Leftover from the MB2 to MB3 move perhaps? As I said, I went through all of them and made them all uniform. All of them now have a Season Number of 0, and all of them have a Sort Name of Specials now. Okay, then that should be fine. Good find.
kpate77 10 Posted July 2, 2014 Posted July 2, 2014 Did you guys find a solution to this? I seem to have the settings checked that you suggested, but I'm still having the issue. I'm on the latest version on MBC using the Chocolate Theme. I have "Show Unplayed Count" checked under View Options. Under Chocolate Views, I have "Use Custom View for Series" checked. These have been checked for quite some time. But I'm experiencing the same problem described by the OP. If this is a flaw that I need to live with, I have no problem with that. I just back out of the series and go back in to get the correct episode. It's annoying, but I can live with it no problem. Much Thanks!
