Thomas64 40 Posted February 10, 2019 Posted February 10, 2019 (edited) Folks - Running a fresh install of both Emby Server 4.0.1.0 and Windows Pro 1809. There seems to be a glitch with the "Users" functionality that I couldn't find an existing post about.. After setting up a new user, when going back into "Users" via the Dashboard - the screen will come up with no data and a spinning wheel. Or, if going into "Settings" via the Web App - the options screen comes up and when I click "Profile", the only thing that happens is the spinning wheel again. This is sporadic. Sometimes it happens directly after restarting the server, sometimes it happens a bit later after having worked fine a few times. I've attached screen prints and logs from these two instances (I think I copied the correctly timed logs). I happened to have only the single user from the installation at the time - "Admin". However, it still happens after adding an everyday user - "Thomas" as well. I have Windows Security ignoring the entire Roaming\Emby-Server Directory structure - so that isn't sporadically locking up any files.. Thanks! Thomas Edited March 8, 2019 by Thomas64
Luke 42217 Posted February 10, 2019 Posted February 10, 2019 Does the browser debug console show any errors?
Thomas64 40 Posted February 10, 2019 Author Posted February 10, 2019 (edited) Here you go Luke - is this what you're looking for? I have 2 users configured - Admin and Thomas. I click either, and this happens.. Yet.. the actual ID's work perfectly as configured when I set them up.. Thanks! Edited March 8, 2019 by Thomas64
Thomas64 40 Posted February 10, 2019 Author Posted February 10, 2019 (edited) Here is a little more info.. If I use the 3 dots and select "open" - same error. If I use the dots and select "library access" - different error: Edited March 8, 2019 by Thomas64
Happy2Play 9806 Posted February 10, 2019 Posted February 10, 2019 @@Luke Look at the urls in the images, mine don't show that url. Mine are localhost:8096/web/index.html#!/useredit.html?userId=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Luke 42217 Posted February 10, 2019 Posted February 10, 2019 Right, he's just completed the startup wizard. @@Thomas64, try closing the browser tab then coming back to the emby web interface. thanks.
Thomas64 40 Posted February 10, 2019 Author Posted February 10, 2019 Hey Luke - no wizards or anything... 1 - (re) start Laptop / Emby Server software 2 - log in as "Admin" (on laptop running Emby Server Software) via MS Edge 3 - go to Users tab from Dashboard 4 - click either user 5 - get error Edge is set to delete all History each time closed (and I've manually had I do so as well).. I typically don't use Edge, but happens from computer in living room using Chrome as well - so I don't think Edge is the culprit.. BTW - seems like the error happens every time now. It would occasionally work before.. Thomas
Thomas64 40 Posted February 10, 2019 Author Posted February 10, 2019 Err... Let me clarify.. #2 - logging into Emby as "admin" (on laptop running Emby Server Software) via MS Edge The user I am logging into the actual laptop with has Admin Rights, just FYI.. Thomas
Happy2Play 9806 Posted February 10, 2019 Posted February 10, 2019 (edited) Your browser is maintaining the "start=wizard#!" that should only appear during initial setup in startupwizard. I can only get the url you have shown by running the startupwizard. http://localhost:8096/web/index.html?start=wizard#!/dashboard.html But closing the tab/browser and relaunching I get this http://localhost:8096/web/index.html#!/dashboard.html What url do you see at login for Emby? Is it a shortcut/bookmark? Edited February 10, 2019 by Happy2Play
Solution Thomas64 40 Posted February 10, 2019 Author Solution Posted February 10, 2019 (edited) Holy Mackeral..!! Do I ever feel stoopid! As this was a brand new build all the way around, I think I just created the bookmark in Edge while configuring Emby during installation.. I just edited that bookmark.. And.. -- http://localhost:8096/web/index.html?start=wizard#!/dashboard.html Whenever I manually make a bookmark for Emby, I just leave off everything past the port. Wow. Sorry for wasting ya'lls time! Thomas Edited February 10, 2019 by Thomas64 1
Thomas64 40 Posted February 10, 2019 Author Posted February 10, 2019 AND - Thanks for the help!! Which I neglected to mention. Thomas
