fiergna 0 Posted February 10, 2019 Posted February 10, 2019 (edited) Hi I am trying to add xmltv epg data without success. What have i done. 1. Add TV Guide Data Providers 2. Country: Switzerland 3. Guide source: XmlTV 4. url: http://xmltv.xmltv.se/channels-Switzerland.xml.gz 5. User agent: EmbyMedia (they say on the website that a proper user-agent has to be set, otherwise no data is send) 6. save Some channels are mapped correct at the start, the other ones i am mapping by myself. But when i go to the epg, thereis no epg data. Any ideas? Sorry for my bad english, its not my native language embyserver.txt Edited February 10, 2019 by fiergna
Luke 42244 Posted February 10, 2019 Posted February 10, 2019 Hi, can you show a screenshot of the mappings? thanks.
Luke 42244 Posted February 10, 2019 Posted February 10, 2019 have you checked the xml contents to see that it has data for these channels?
fiergna 0 Posted February 11, 2019 Author Posted February 11, 2019 Yes, i did check them, not all have, but the majority http://xmltv.xmltv.se/00index.html
Luke 42244 Posted February 13, 2019 Posted February 13, 2019 @@fiergna, look at the xml data: http://xmltv.xmltv.se/channels-Switzerland.xml.gz There's no guide data in this xml, only channel logos.
fiergna 0 Posted February 15, 2019 Author Posted February 15, 2019 @@Luke The data are in here (http://xmltv.xmltv.se/), but this url doesent work. I was thinking this (http://xmltv.xmltv.se/channels-Switzerland.xml.gz) url functions like a navigation page the the xml files located in (http://xmltv.xmltv.se/) here How can i set up to use this?
Luke 42244 Posted February 15, 2019 Posted February 15, 2019 An xmltv url will have both channels and programs all in one xml document.
