PenkethBoy 2068 Posted February 9, 2019 Posted February 9, 2019 If i run a query against the /artists end point and dont specify a ParentID then i get itemcounts returned - e.g AlbumCount,SongCount However if i add the ParentID to limit to a particular Music Library - i do not get Itemcounts returned Tested via Swagger - 4.1.0.7 beta server So is this as it should be? Or is it an omission/bug? Without ParentID With ParentID No itemcounts returned
Luke 42239 Posted February 9, 2019 Posted February 9, 2019 The counts would be based on media underneath the parent id
PenkethBoy 2068 Posted February 9, 2019 Author Posted February 9, 2019 Not sure i understand your comment The parentID supplied is a Music Library so the Media is "music" - so you are saying it should work?
