steve1977 67 Posted June 7, 2014 Posted June 7, 2014 if you disable the startup scan via scheduled tasks, it will work just fine. Unfortunately, this is no longer the case. Until the last server update, this is what I did. I disabled the startup scan and just manually used it when needed. Unfortunately, the library no longer shows if you disable the startup scan (as confirmed by several users in this thread). I don't think it is a big deal as I can enable it and wait a few minutes. But wanted to share that the server behavior has changed and now a scan upon restart is required.
steve1977 67 Posted June 7, 2014 Posted June 7, 2014 i just tested a couple days ago and it was fine. Sounds good, let me test again whether this works again. I rarely restart my server, so this may be fixed by now.
