vurt 19 Posted February 8, 2019 Posted February 8, 2019 (edited) Hi everyone. I've had this issue since Kodi 17.6 and it persisted with 18. And it's present through the iterations of Emby for Kodi addon (currently on 4.0.5). I posted in the Kodi forum as well because I don't know if the problem lies with Emby or Kodi. Subtitles play within Emby's web app. For the same show, subtitle doesn't display in Kodi even though Kodi's OSD indicates an external subtitle is present. I looked in the directory and confirm the subtitle is there, same name as the video file with language code "en" appended before ".srt". If I use Kodi to download a subtitle, Kodi will display it. Here's a log: https://paste.ubuntu.com/p/ps76zWhSzW/ Towards the end of the log when I play the show "Insecure S01E02", that's where it happened. The subtitle's filename is "Insecure.S01E02.720p.BluRay.x264-DEMAND-postbot.en.srt". It's probably a silly user error but I don't know how to troubleshoot it and I've googled and searched. Edited February 8, 2019 by vurt
iBoss 31 Posted February 8, 2019 Posted February 8, 2019 (edited) Same here @@ebr it happed with same files I send them to you Video file + SRT: - emby Kody: Max. bitrate: Direct play - subtitle sometime appeared and sometime not (need to be fixed) Low bitrate: Transcoded and subtitle is not shown (need to be fixed) Video file + ASS: - emby Kody: Max. bitrate: Direct play - subtitle is not shown (need to be fixed) Low bitrate: Transcoded and subtitle is not shown (need to be fixed) emby server ver. 4.0.1.0 Ubuntu 16.04.5 LTS Kodi emby 1.0.4 Kodi 18.0 embyserver.txt ffmpeg-transcode_(video_srt).txt ffmpeg-transcode_(video_ass).txt Edited February 8, 2019 by iBoss
vurt 19 Posted February 8, 2019 Author Posted February 8, 2019 I'm appending a new log: https://paste.ubuntu.com/p/dxZBZ2wDZt/
Angelblue05 4132 Posted February 8, 2019 Posted February 8, 2019 Can you point out the specific instance in your log? Thanks.
vurt 19 Posted February 8, 2019 Author Posted February 8, 2019 Hi, in my first log: Towards the end of the log when I play the show "Insecure S01E02", that's where it happened. The subtitle's filename is "Insecure.S01E02.720p.BluRay.x264-DEMAND-postbot.en.srt". In the second log, the filename is "Insecure.S01E04.720p.BluRay.x264-DEMAND-postbot.mkv". Let me know if that helps. Otherwise I'll restart Kodi and try to get a cleaner log.
vurt 19 Posted February 8, 2019 Author Posted February 8, 2019 Sorry here's a new log after I restarted Kodi, should be cleaner: https://paste.ubuntu.com/p/MVCKMtHw7V/ Here's something odd: After I restarted Kodi, the file Insecure.S01E04.720p.BluRay.x264-DEMAND-postbot.mkv now plays with subtitles when it didn't before. However, when I tried the next episode, Insecure.S01E05.720p.BluRay.x264-DEMAND.mkv, the same problem, no subtitle display despite the external sub. Maybe this will make it easier to compare what's going on. Thank you very much for having a look.
iBoss 31 Posted February 8, 2019 Posted February 8, 2019 Here's something odd: After I restarted Kodi, the file Insecure.S01E04.720p.BluRay.x264-DEMAND-postbot.mkv now plays with subtitles when it didn't before. However, when I tried the next episode, Insecure.S01E05.720p.BluRay.x264-DEMAND.mkv, the same problem, no subtitle display despite the external sub. exactly the same issue also if I want to select the subtitle while the video is playing, sometime I see the subtitle there but it's not shown on the video
iBoss 31 Posted February 9, 2019 Posted February 9, 2019 (edited) The ASS subtitle with attached font issue from the Kodi I have already submitted this issue to Kodi forum Edited February 9, 2019 by iBoss 1
Angelblue05 4132 Posted February 13, 2019 Posted February 13, 2019 (edited) I don't believe this issue is related to the add-on. According to your log, both playback, the subtitles was appended to the stream. Were subtitles enabled? If they were, do you have that issue in the webclient too? If not, there were subtitles issues in Kodi Leia so I'd look there. Edited February 13, 2019 by Angelblue05 1
vurt 19 Posted February 14, 2019 Author Posted February 14, 2019 Thank you for letting us know @@Angelblue05, I'll convey that back to the Kodi discussion.
