Ottone 1 Posted February 7, 2019 Posted February 7, 2019 (edited) Hi, I hope this is the right place to post this. I installed emby on Mint 19.1 mate and the dashboard on localhost 8096 is all green and promising except...I don't see my bluray player among the devices. On Windows I used Serviio and the connection was set in 1 2 3. Any idea how to solve this? Greetings Edited February 9, 2019 by Ottone
Sammy 791 Posted February 7, 2019 Posted February 7, 2019 Is your Blu-ray player DNLA compliant? Does it see the rest of your network DNLA devices? Did you forward port 8096 in your router? Sent from my SM-G960U1 using Tapatalk
Ottone 1 Posted February 7, 2019 Author Posted February 7, 2019 Is your Blu-ray player DNLA compliant? Does it see the rest of your network DNLA devices? Did you forward port 8096 in your router? Sent from my SM-G960U1 using Tapatalk Thanks for the prompt reply. Answers: Yes I don't have other devices How can I do that?
Ottone 1 Posted February 9, 2019 Author Posted February 9, 2019 I've been messing up with the settings and now it works. What did the trick I think was opening port 8096 in the firewall. Should have thought about it before but hey, newbie, right? 1
Sammy 791 Posted February 9, 2019 Posted February 9, 2019 I've been messing up with the settings and now it works. What did the trick I think was opening port 8096 in the firewall. Should have thought about it before but hey, newbie, right? So you figured out how to port forward in your router?
Ottone 1 Posted February 9, 2019 Author Posted February 9, 2019 So you figured out how to port forward in your router? I don't even know what that means...I simply set a rule for the firewall to open the port for incoming traffic, that's all
