pir8radio 1313 Posted February 7, 2019 Posted February 7, 2019 Some of my recordings stop after like 2 mins... Emby logs says ffmpeg exited code 0, so it thinks all is well.. -async 1 -vsync -1 -fflags +discardcorruptts+fillwallclockdts -stream_loop -1 -reconnect_at_eof 1 -reconnect_streamed 1 -reconnect_delay_max 2 -analyzeduration 5000000 -i "http://iptv.com/play/2760.ts?token=eyJ1c2VybmFtZSI6HMifQ==" -codec:v:0 copy -fflags +genpts -map_metadata -1 -threads 0 -codec:a:0 copy -sn -y "E:\LiveTV Recordings\Series\Botched\Season 5\Botched S05E10.ts" ffmpeg version 4.0.2-emby_2018_12_09-g5abbb1430d+238 Copyright (c) 2000-2018 the FFmpeg developers built with gcc 8.2.1 (Rev1, Built by MSYS2 project) 20181207 configuration: --disable-autodetect --enable-amf --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --enable-sdl2 --disable-debug --enable-ffnvcodec --enable-nvdec --enable-gmp --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwavpack --enable-libwebp --enable-libxml2 --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libaom --enable-version3 --enable-libzvbi --enable-gnutls --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++ --extra-cflags=-DLIBXML_STATIC --extra-libs=-liconv libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100 Input #0, mpegts, from 'http://iptv.com/play/2760.ts?token=eyJ1c2VybmFthc33JkIjzNHVqZmpHMifQ==': Duration: N/A, start: 71481.106278, bitrate: N/A Program 1 Metadata: service_name : ?Service01 service_provider: ?FFmpeg Stream #0:0[0xd3]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(progressive), 1280x720 [SAR 1:1 DAR 16:9], Closed Captions, 59.94 fps, 59.94 tbr, 90k tbn, 119.88 tbc Stream #0:1[0xdd]: Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 124 kb/s Output #0, mpegts, to 'E:\LiveTV Recordings\Series\Botched\Season 5\Botched S05E10.ts': Metadata: encoder : Lavf58.12.100 Stream #0:0: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(progressive), 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 59.94 fps, 59.94 tbr, 90k tbn, 90k tbc Stream #0:1: Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 124 kb/s Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help frame= 600 fps=123 q=-1.0 size= 5376kB time=00:00:10.00 bitrate=4401.7kbits/s speed=2.06x frame= 900 fps= 91 q=-1.0 size= 8192kB time=00:00:15.01 bitrate=4468.4kbits/s speed=1.51x frame= 1201 fps= 76 q=-1.0 size= 11264kB time=00:00:20.01 bitrate=4610.3kbits/s speed=1.27x frame= 1500 fps= 79 q=-1.0 size= 14336kB time=00:00:25.02 bitrate=4693.1kbits/s speed=1.31x frame= 1800 fps= 73 q=-1.0 size= 17920kB time=00:00:30.03 bitrate=4887.3kbits/s speed=1.21x frame= 2101 fps= 71 q=-1.0 size= 20736kB time=00:00:35.03 bitrate=4849.2kbits/s speed=1.18x frame= 2400 fps= 68 q=-1.0 size= 23808kB time=00:00:40.04 bitrate=4870.7kbits/s speed=1.14x frame= 2700 fps= 68 q=-1.0 size= 26880kB time=00:00:45.05 bitrate=4887.3kbits/s speed=1.13x frame= 3000 fps= 67 q=-1.0 size= 29696kB time=00:00:50.04 bitrate=4860.7kbits/s speed=1.12x frame= 3300 fps= 66 q=-1.0 size= 32256kB time=00:00:55.06 bitrate=4799.0kbits/s speed= 1.1x frame= 3601 fps= 66 q=-1.0 size= 35328kB time=00:01:00.05 bitrate=4819.0kbits/s speed=1.09x frame= 3900 fps= 66 q=-1.0 size= 38656kB time=00:01:05.06 bitrate=4866.9kbits/s speed= 1.1x frame= 4200 fps= 65 q=-1.0 size= 41472kB time=00:01:10.08 bitrate=4847.9kbits/s speed=1.08x frame= 4500 fps= 64 q=-1.0 size= 44288kB time=00:01:15.07 bitrate=4832.8kbits/s speed=1.07x frame= 4800 fps= 64 q=-1.0 size= 47616kB time=00:01:20.08 bitrate=4870.7kbits/s speed=1.07x frame= 5101 fps= 64 q=-1.0 size= 50688kB time=00:01:25.08 bitrate=4880.5kbits/s speed=1.07x frame= 5400 fps= 64 q=-1.0 size= 53248kB time=00:01:30.09 bitrate=4841.9kbits/s speed=1.06x frame= 5700 fps= 63 q=-1.0 size= 56832kB time=00:01:35.10 bitrate=4895.4kbits/s speed=1.06x frame= 6000 fps= 63 q=-1.0 size= 59648kB time=00:01:40.09 bitrate=4881.7kbits/s speed=1.04x frame= 6300 fps= 63 q=-1.0 size= 62720kB time=00:01:45.10 bitrate=4888.3kbits/s speed=1.05x frame= 6600 fps= 63 q=-1.0 size= 65280kB time=00:01:50.10 bitrate=4857.1kbits/s speed=1.06x frame= 6900 fps= 63 q=-1.0 size= 68864kB time=00:01:55.11 bitrate=4900.6kbits/s speed=1.05x frame= 7200 fps= 63 q=-1.0 size= 71936kB time=00:02:00.12 bitrate=4905.6kbits/s speed=1.05x [http @ 0000026cfb7ccf80] Will reconnect at 77435320 in 0 second(s), error=End of file. [http @ 0000026cfb7ccf80] Will reconnect at 77435320 in 1 second(s), error=End of file. Seek to start failed. http://iptv.com/play/2760.ts?token=eyJ1c2VybmInBpcjhyYWZmprMifQ==: Function not implemented frame= 7500 fps= 58 q=-1.0 size= 74752kB time=00:02:05.12 bitrate=4894.2kbits/s speed=0.965x frame= 7500 fps= 58 q=-1.0 Lsize= 74903kB time=00:02:05.12 bitrate=4904.1kbits/s speed=0.962x video:66650kB audio:1956kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 9.178483% The only thing i see that looks strange is below, but I don't know if that means the stream disconnected? If so why did it not restart? but it looks like it does starts at frame 7500? I still don't get what happened lol. what is "Function not implemented"? [http @ 0000026cfb7ccf80] Will reconnect at 77435320 in 0 second(s), error=End of file. [http @ 0000026cfb7ccf80] Will reconnect at 77435320 in 1 second(s), error=End of file. Seek to start failed. http://iptv.com/play/2760.ts?token=eyJ1c2VybmInBpcjhyYWZmprMifQ==: Function not implemented
Luke 42244 Posted February 8, 2019 Posted February 8, 2019 try putting the url into the browser address bar and see if it eventually disconnects.
