rms8 14 Posted February 12, 2019 Author Posted February 12, 2019 Thanks for the feedback. Any ides yet on how to correct it?
Luke 42237 Posted February 12, 2019 Posted February 12, 2019 As I mentioned earlier I am still trying to chase down the root cause. The manual editing is a workaround that you can use for now. Thanks.
rms8 14 Posted February 12, 2019 Author Posted February 12, 2019 As I mentioned earlier I am still trying to chase down the root cause. The manual editing is a workaround that you can use for now. Thanks. THX a million Luke !!!!!!
rms8 14 Posted February 22, 2019 Author Posted February 22, 2019 As I mentioned earlier I am still trying to chase down the root cause. The manual editing is a workaround that you can use for now. Thanks. Hi Luke, any closer to figuring out what's up with this issue? THANKS Luke! Rob
rms8 14 Posted March 8, 2019 Author Posted March 8, 2019 Not yet but hopefully soon. Thanks. Luke, In the last week I added 2 new movies to the server. When I started up EMC, both movies were now being displayed correctly on the EHS. No idea what changed, but at this point it appears to be working normally again. Rob
