egill 1 Posted February 5, 2019 Posted February 5, 2019 (edited) Hi, my Emby server stopped importing new media, probably with 4.0.1. I say probably because I was also doing some media cleanup manually around the same time. And thank for Emby, really, really like this service. Best regards, Egill Edited February 6, 2019 by egill
Luke 42217 Posted February 6, 2019 Posted February 6, 2019 hi @@egill, can you please give an example? What exactly did not import? Thanks.
Solution egill 1 Posted February 6, 2019 Author Solution Posted February 6, 2019 Emby was not importing new content (ripped movies) in a certain subfolder on a networked drive. Last night I verified that moving one of the new content to another folder in the same Library did result in the content being imported. So, I then ran scandisk on the drive and some errors were found and corrected. Running Scan on the Emby library resulted in successful import. So the fault was not with Emby and the issue is resolved. Best regards, Egill 1
