snwaine 1 Posted February 5, 2019 Posted February 5, 2019 (edited) Hi all I have just made the jump from Plex to emby but I'm having an issue. The Fire Stick app version 1.6.79a is not automatically playing the next episode in the season it works on web app but not the fire stick. I'm running server version 4.0.1.0 all setting are set to allow it to play the next episode but it just goes back to the episode selection screen. If I remote play from my phone then it plays the next episode with out me doing anything. Has anyone got any ideas how to fix this please. Edited February 5, 2019 by snwaine
arrbee99 1836 Posted February 5, 2019 Posted February 5, 2019 Apologies if you've checked already, but am wondering if there's an option for that on the FireTV Emby app itself ? Unfortunately I can't check on mine as its in use at the moment by the other half...
snwaine 1 Posted February 5, 2019 Author Posted February 5, 2019 Hi there thanks for the reply, yes the fire stick emby app has an option to play the next episode automatically but it doesn't seem to be working.
arrbee99 1836 Posted February 5, 2019 Posted February 5, 2019 Ah well, sorry again, but that sounds more like a job for one of the devs...
snwaine 1 Posted February 5, 2019 Author Posted February 5, 2019 Well thanks anyway for having a look.
ebr 16338 Posted February 6, 2019 Posted February 6, 2019 Hi. Can we please look at an example? Also, are you sure your episodes are all properly identified with season and episode numbers? How to Report a Problem
