quinnby95 0 Posted February 5, 2019 Posted February 5, 2019 I am trying to watch my shows on the Emby app for firestick, it shows that I have a 5.1 audio track but just downmixes it to stereo. The option for that is turned off in settings and ONLY does it on tv shows, every movie that I play with 5.1 surround plays perfectly fine. Any ideas?
ebr 16337 Posted February 5, 2019 Posted February 5, 2019 Hi. Can we please look at an example? How to Report a Problem
quinnby95 0 Posted February 5, 2019 Author Posted February 5, 2019 Just sent the logs through my firestick. I was playing Star Wars the clone Wars and the user name that sent it was "Quinn & Sarah" @ 5:37pm
ebr 16337 Posted February 6, 2019 Posted February 6, 2019 Hi. There should have been an ffmpeg log produced from that playback. Can we please see that? Also, it looks like that item has a lot of different audio tracks. Be sure you've selected the proper one.
quinnby95 0 Posted February 6, 2019 Author Posted February 6, 2019 I think this is the log file for it here. It does have many different sound profiles but they are all 5.1 and none of them would play through 5.1. I also tried playing my other show The Americans which is 5.1 but that also wouldn't work. Put on Lego Movie which is 5.1 and it worked no problem.
Luke 42246 Posted February 6, 2019 Posted February 6, 2019 Can you please attach the information requested in How to Report a Problem ? Thanks !
quinnby95 0 Posted February 6, 2019 Author Posted February 6, 2019 Oops sorry forgot to click the attach this file button. Here is the log file! ffmpeg-transcode-d484bcbd-c55d-48cb-8aca-bf801d78a114_1.txt
ebr 16337 Posted February 6, 2019 Posted February 6, 2019 Okay, it looks like these are all 5.1 AAC tracks and the device appears to not natively support that (although, based on docs, it seems it should) so it is being mixed down. What exact model of Fire Stick is this?
quinnby95 0 Posted February 6, 2019 Author Posted February 6, 2019 I am using the firestick basic edition from Canada. Here is the exact link to the device https://www.amazon.ca/Stick-Basic-Streaming-Media-Player/dp/B01ETRGE68 Its weird that its saying that because the movies played fine in 5.1 and up until earlier yesterday that same series played fine in 5.1
ebr 16337 Posted February 6, 2019 Posted February 6, 2019 Its weird that its saying that because the movies played fine in 5.1 and up until earlier yesterday that same series played fine in 5.1 The movies probably have DD or DTS tracks. Can you confirm that?
quinnby95 0 Posted February 6, 2019 Author Posted February 6, 2019 The movies have AAC 5.1 as well, I have attached a screen shot with the info on it. It only down mixes when it being played from the Series folder, everything in movies plays fine. Its incredibly strange, I tried rebooting the server, reinstalling the Firestick app and updating the OS as well, none of it fixed it.
ebr 16337 Posted February 6, 2019 Posted February 6, 2019 Do you have a log of one of the movie playback sessions?
quinnby95 0 Posted February 6, 2019 Author Posted February 6, 2019 Annoyingly enough I can't find one for it, I even tried playing other shows/movies to create log fies and either I can't find them or they aren't there. I did play around with some of my other series however. This issue ONLY shows up in series that are AAC 5.1, anything that is Dolby 5.1 plays fine. Is there a way to try and update ffmpeg?
ebr 16337 Posted February 6, 2019 Posted February 6, 2019 The movies are probably direct playing. But, with the ones you are having an issue with, the audio is being stream copied so should be functionally equivalent...
quinnby95 0 Posted February 6, 2019 Author Posted February 6, 2019 That was my assumption as well. I have done some research and it LOOKS like for some reason sometimes FFMPEG will downmix AAC files to stereo even though their 5.1, however if its AC3 then it will play fine. I am going to try converting one of the seasons to AC3 and see if that works. According to one of the youtube videos I watched, it just decides to do it at random.
