eist1 3 Posted February 5, 2019 Posted February 5, 2019 I am having an issue with FireTV LiveTV playing back Direct Streams that are ts. I looked at info in Stats for Nerds and the non working channels have below information Playback Info Player: ExoPlayer Play method: Direct Stream type: ts Working channels show Play method: Remux Stream type: HLS I have attached the ffmpeg-remux log file. It says Conversion failed! I see the same thing on any of the non-working channels. Could someone look and see if there is something that needs to be fixed in the Trancoding settings? ffmpeg-remux.txt
Luke 42244 Posted February 6, 2019 Posted February 6, 2019 Hi there, can you attach the emby server log as well? thanks.
eist1 3 Posted February 6, 2019 Author Posted February 6, 2019 Thanks for the reply! I ended up figuring it out by trial and error. It looks to have been a issue with xTeVe. I rebuilt the whole config, filters, mapping and all channels are now working. Not sure what it was, I did have Stream Buffering Enabled initially, but disabled it and it still did not work, so I rebuilt the config from scratch and all channels are now working. The channels that were Play method: Direct Stream type: ts and not working are now Play method: Remux Stream type: HLS and are working. I'll let you know if anything stops working again.
