paralepepipedo 1 Posted February 5, 2019 Posted February 5, 2019 hello friends, is there any configuration that I am not applying or will be the problem of the version ?. all movies look like a rectangle on the screen and not on the entire screen, the focus option simply moves the image up.
Luke 42246 Posted February 5, 2019 Posted February 5, 2019 Do your videos have black borders embedded?
ebr 16337 Posted February 5, 2019 Posted February 5, 2019 What does it look like if you select "Normal"?
paralepepipedo 1 Posted February 5, 2019 Author Posted February 5, 2019 Do your videos have black borders embedded? no, they are normal movies of 1080, before I used the andriod version and I had no problems, I deleted it to install "android tv" but all the movies look like the image. and for bad luck the new version "android" only I see black screen.
paralepepipedo 1 Posted February 5, 2019 Author Posted February 5, 2019 What does it look like if you select "Normal"? only the last option is selected, the normal option is marked because it is where the cursor is to scroll through the other options.
ebr 16337 Posted February 5, 2019 Posted February 5, 2019 Yes, but what does it look like if you select that one? What device is this? Starting to sound like maybe a non-standard Android box...?
paralepepipedo 1 Posted February 5, 2019 Author Posted February 5, 2019 Yes, but what does it look like if you select that one? What device is this? Starting to sound like maybe a non-standard Android box...? try in normal, vertical and horizontal but the picture of the film that moves higher or lower but I can not really stretch and adapt to the screen. it's a xgimi h1 projector CPU: Mstar 6A928 Cortex-A17 Quadcore 1.7GHz PU: Mali-760MP4 RAM: 3GB DDR3 Storage: 16GB eMMC System: GUMI based on Android 5.1.1 with the android version it worked fine, but I uninstalled it to install the android tv version.
ebr 16337 Posted February 5, 2019 Posted February 5, 2019 Did you build this box yourself? The issue is that it is Android 5.1 which doesn't support these zoom modes right now. I thought this was an issue with the Fire but, apparently, it is the OS version - its just that the Fires are pretty much the only Android TV boxes that run that old of a version of Android.
paralepepipedo 1 Posted February 6, 2019 Author Posted February 6, 2019 Did you build this box yourself? The issue is that it is Android 5.1 which doesn't support these zoom modes right now. I thought this was an issue with the Fire but, apparently, it is the OS version - its just that the Fires are pretty much the only Android TV boxes that run that old of a version of Android. Did you build this box yourself? I wish I had the mind to make jejejejee, but no, I bought it from China. Well for what you tell me I have no hope with this version, but is there the possibility that an older version works for me? or an old version of the other android app, because the new one does not work either, when opening the screen remains black.
ebr 16337 Posted February 6, 2019 Posted February 6, 2019 Hi. Sorry, I don't know. A lot of those cheap boxes from China are just that and don't have proper implementations of everything.
paralepepipedo 1 Posted February 7, 2019 Author Posted February 7, 2019 Hi. Sorry, I don't know. A lot of those cheap boxes from China are just that and don't have proper implementations of everything. F Finally the only version that works for me is 3.0.21, from then on they all remain on the black screen. the android tv versions unfortunately none worked with full screen the only solution was to use external player.
clarkss12 304 Posted February 7, 2019 Posted February 7, 2019 (edited) https://us.gearbest.com/projectors/pp_656107.html I would not call that device, cheap......... Edited February 7, 2019 by clarkss12
Spaceboy 2573 Posted February 7, 2019 Posted February 7, 2019 https://us.gearbest.com/projectors/pp_656107.html I would not call that device, cheap......... its cheap in comparison to a quality equivalent that works 1
paralepepipedo 1 Posted February 7, 2019 Author Posted February 7, 2019 its cheap in comparison to a quality equivalent that works i must say it's much better than any epson benq sony of the same level of price
Spaceboy 2573 Posted February 7, 2019 Posted February 7, 2019 i must say it's much better than any epson benq sony of the same level of pricewell it’s clearly not better than something that works! But my point was “cheap” is a relative term, not an absolute term. A product could be £10K but if it does what it needs to then it may be cheap in comparison to the problem that it solves
