OllieUK 0 Posted February 4, 2019 Posted February 4, 2019 I'm running Version 4.0.1.0 on FreeNAS. I have both a TV Series and a Movies library. The TV Series library is showing parental ratings. The Movies library is not. When I however look at my various users, who are filtered for different parental ratings, the filter seems to be effective for movies, although nothing is shown in the metadata manager. Rescanning the library and replacing all metadata throws a small number of ffprobe errors, but no more. What am I missing?
Happy2Play 9811 Posted February 4, 2019 Posted February 4, 2019 I'm running Version 4.0.1.0 on FreeNAS. I have both a TV Series and a Movies library. The TV Series library is showing parental ratings. The Movies library is not. When I however look at my various users, who are filtered for different parental ratings, the filter seems to be effective for movies, although nothing is shown in the metadata manager. Rescanning the library and replacing all metadata throws a small number of ffprobe errors, but no more. What am I missing? Can you show some screenshots of a specific example. Since you mention Metadata Manager, the layout has changed and you may be looking at the folder instead of the media item.
OllieUK 0 Posted February 5, 2019 Author Posted February 5, 2019 Here it is. Reasonably sure I'm in the right place.
ebr 16332 Posted February 5, 2019 Posted February 5, 2019 Click the little triangle to the left of that entry in the left side bar...
OllieUK 0 Posted February 5, 2019 Author Posted February 5, 2019 Okay. Now I see it. Allow me to say: To me it is very confusing, having the actual movie inside a folder with the same name and then showing attributes on the folder that are essentially the same as the movie below. I would suggest either removing "duplicate" attributes between the folder and the movie, or otherwise populating the folder attributes from the child element (movie) itself in cases where there is no more than one child element.
