Quintwm 0 Posted February 4, 2019 Posted February 4, 2019 I need some help setting up my AVerymedia tuner on emby, is it supported on emby? Because it can’t be found when searching for tuner Thanks
Luke 42234 Posted February 4, 2019 Posted February 4, 2019 It's not natively supported on Emby, but you can still probably use it via a live tv plugin. Are you on Windows?
Luke 42234 Posted February 5, 2019 Posted February 5, 2019 Ok, so you could install the next pvr software, get that fully working: https://www.nextpvr.com/ Then once you've done that, the next pvr plugin for emby can help you utilize the tuner.
Quintwm 0 Posted February 5, 2019 Author Posted February 5, 2019 Ok, thanks. I’ll try that and see if it works. Wendall
Quintwm 0 Posted February 5, 2019 Author Posted February 5, 2019 I think that I still need some guidance because I tried it and still not working for me Wendall
SHSPVR 125 Posted February 5, 2019 Posted February 5, 2019 PS. it call AVerMedia which model do you have You need to setup NextPVR first
Quintwm 0 Posted February 6, 2019 Author Posted February 6, 2019 How do you setup NextPVR, because I have installed it already
arrbee99 1836 Posted February 6, 2019 Posted February 6, 2019 Maybe see if this helps - https://www.nextpvr.com/nwiki/pmwiki.php?n=QuickStart.QuickStart
SHSPVR 125 Posted February 6, 2019 Posted February 6, 2019 How do you setup NextPVR, because I have installed it already Google nextpvr setup guide there are plenty of video to give an idea on how it work.
