XSR 12 Posted February 4, 2019 Posted February 4, 2019 I have used long time ago IIS7 Geoblock Module (https://sourceforge.net/projects/iis7geoblockmod/) to block certain countries from accessing emby with IISproxy. This sofware deveploment has ended, but I found updated source from github that works IIS 10, but only with IPv4 address. It supports also new GeoIP2 database format. Source code: https://github.com/RvdHout/IIS-GeoIP2block-Module Is here anybody skilled help me to add IPv6 support to it?
Turbofiero 5 Posted January 17, 2024 Posted January 17, 2024 This is old but figured id mention, rvdHout's build of the GeoIP2block module now supports ipv6 One issue with it is you cannot have all sites using the same maxmind DB, otherwise you will get sporadic 500 errors.... simply hardlink the db into each of your sites bin folders and direct the config for each site there
