bshiers82501 0 Posted February 3, 2019 Posted February 3, 2019 I have Emby setup with an IPTV Provider. I am using xtream editor to edit the m3u file to only get the channels I want out of it. I then late the m3u and EPG urls into emby. I have refreshed guide data and I see the channels in the guide but no guide data. I’m clearly doing something wrong. Running emby server on windows 7.
arrbee99 1836 Posted February 3, 2019 Posted February 3, 2019 Just as a guess in the meantime, do you need to map the channels to the guide ? https://github.com/MediaBrowser/Wiki/wiki/Live-TV-Channel-Mapping
Luke 42244 Posted February 4, 2019 Posted February 4, 2019 Yes the channels most likely need to be mapped. Please let us know if this helps. Thanks.
bshiers82501 0 Posted February 4, 2019 Author Posted February 4, 2019 When I bring up the channel mapping window it’s blank.
kanipek 230 Posted February 4, 2019 Posted February 4, 2019 Sounds like there is an error in one or both of the files(urls) If you look at the log in an editor like notepad++ you will be able to see the error (if there is one). It will tell you what line number and what character position.
rfeng33 0 Posted February 4, 2019 Posted February 4, 2019 (edited) 2019-02-04 07:01:45.490 Info App: xmltv path: https://xtream-editor.com/en/get/epg/blahblah 2019-02-04 07:01:45.490 Info App: Downloading xmltv listings from https://xtream-editor.com/en/get/epg/blahblah 2019-02-04 07:01:45.499 Info HttpClient: GetTempFileResponse url: https://xtream-editor.com/en/get/epg/blahblah 2019-02-04 07:01:46.280 Error HttpServer: Error processing request *** Error Report *** Version: 4.0.1.0 Command line: C:\Users\whdvr\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: C:\Users\whdvr\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\whdvr\AppData\Roaming\Emby-Server\system System.Xml.XmlException: System.Xml.XmlException: Root element is missing. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlTextReaderImpl.Read() at System.Xml.XmlReader.ReadToDescendant(String name) at Emby.XmlTv.Classes.XmlTvReader.GetChannels() at Emby.LiveTV.Listings.XmlTv.XmlTvProvider.GetChannels(ListingsProviderInfo info, CancellationToken cancellationToken) at MediaBrowser.Api.LiveTv.LiveTvService.Get(GetChannelMappingOptions request) at Emby.Server.Implementations.Services.ServiceExecGeneral.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, ILogger logger, String operationName, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, String urlString, String host, String localPath, CancellationToken cancellationToken) Source: System.Private.Xml TargetSite: Void Throw(System.Exception) at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.ParseDocumentContent() at System.Xml.XmlTextReaderImpl.Read() at System.Xml.XmlReader.ReadToDescendant(String name) at Emby.XmlTv.Classes.XmlTvReader.GetChannels() at Emby.LiveTV.Listings.XmlTv.XmlTvProvider.GetChannels(ListingsProviderInfo info, CancellationToken cancellationToken) at MediaBrowser.Api.LiveTv.LiveTvService.Get(GetChannelMappingOptions request) at Emby.Server.Implementations.Services.ServiceExecGeneral.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, ILogger logger, String operationName, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, String urlString, String host, String localPath, CancellationToken cancellationToken) That's what I'm seeing I'm guessing it's an issue on the remote end? The listings do pull in if I use the same link with xteve though. Edited February 4, 2019 by rfeng33
