moldov 0 Posted February 3, 2019 Posted February 3, 2019 (edited) HI im trying to add Persons to movies manually (porn) this works well, but on the Person page i can not see the movies. on the movie page i can see the persons does this only work if a imdb-id is provided? i thought the person works like tags, but they are also missing in search search the person does work, but only the person itself and if the name is in the filename no movies found where i manually added the person/tag any ideas? i did allready a full scan afterwards thanks for help Version 3.3.1.0 running on freenas/docker Edited February 3, 2019 by moldov
PenkethBoy 2068 Posted February 3, 2019 Posted February 3, 2019 Thats a very old version - is there not a newer version - as cant remember how 3.3 works as we are now on version 4
Luke 42217 Posted February 3, 2019 Posted February 3, 2019 In version 4, you can now see home videos that people are attached to, whereas previously you could not.
moldov 0 Posted February 4, 2019 Author Posted February 4, 2019 thanks, I thought so will try to install version 4 on freenas
