snwaine 1 Posted February 3, 2019 Posted February 3, 2019 (edited) Hi all I have just made the jump from Plex to emby but I'm having an issue. The Fire Stick app version 1.6.79a not automatically playing the next episode in the season it works on web app but not the fire stick. I'm running server version 4.0.1.0 all setting are set to allow it to play the next episode but it just goes back to the episode selection screen. Has anyone got any ideas how to fix this please. Edited February 3, 2019 by snwaine
Angelblue05 4132 Posted February 3, 2019 Posted February 3, 2019 (edited) What if you try to do the same, using the web app remote control to play to the fire stick? Same thing happens? Alexa uses the remote control api from the server. But just to make sure, let me know. Thank you. Edited February 3, 2019 by Angelblue05
snwaine 1 Posted February 3, 2019 Author Posted February 3, 2019 Hi thanks for the reply it worked when I did that just not from the app it's self ???
Angelblue05 4132 Posted February 3, 2019 Posted February 3, 2019 Can you tell me exactly what you said? https://emby.media/community/index.php?/topic/50015-how-to-report-a-problem/
snwaine 1 Posted February 3, 2019 Author Posted February 3, 2019 (edited) It doesn't say anything on the fire stick it just finishs playing the current episode and then returns to the previous screen and if I remote playback from the web app to the fire stick it plays fine, then plays the next episode with out any problems. Edited February 3, 2019 by snwaine
Angelblue05 4132 Posted February 3, 2019 Posted February 3, 2019 I just want to know your request to initiate playback, otherwise I can't find your request in logs to fix your issue.
snwaine 1 Posted February 3, 2019 Author Posted February 3, 2019 Sorry there seems to be some confusion I'm not using Alexa voice commands I'm using the fire stick remote.
Angelblue05 4132 Posted February 3, 2019 Posted February 3, 2019 Ok you posted in the Alexa subforums. Here you go. https://emby.media/community/index.php?/forum/147-android-tv-fire-tv/
snwaine 1 Posted February 3, 2019 Author Posted February 3, 2019 Ok sorry about that thanks for your help 1
