bretswinney 22 Posted February 3, 2019 Posted February 3, 2019 Having an issue using when I set iptv to only allow one stream. Once it is back to 0 it works fine but then I have issues with having too many streams. Sent from my iPhone using Tapatalk
bretswinney 22 Posted February 3, 2019 Author Posted February 3, 2019 This is me reporting a problem. Sent from my iPhone using Tapatalk
Luke 42244 Posted February 3, 2019 Posted February 3, 2019 I understand, but in order for us to best help you we need the information requested in my link above. Thanks !
bretswinney 22 Posted February 3, 2019 Author Posted February 3, 2019 Iptv m3u tuner Simultaneous stream limit when set to 1 will not allow a stream to play. Works when set to 0 but that basically is disabling it. Sent from my iPhone using Tapatalk
Carlo 4561 Posted February 4, 2019 Posted February 4, 2019 Next time try and upload the actual TXT file file vs coping the data into an RTF. Some people use tools set up with scripts to look for specific key words and what not and having the file in text format helps. 1
Luke 42244 Posted February 5, 2019 Posted February 5, 2019 Yes can you please upload a plain text version, this is actually quite hard to read in wordpad. Also if there was an ffmpeg log, please attach that too. Thanks.
