Tiberius76 0 Posted February 2, 2019 Posted February 2, 2019 Help! I use emby with out issue through the app on a few different devices, XB1, Roke Tv, etc... but when we tried an Amazon Fire stick we ran into this problem: When loading into the emby app on the fire stick, we skip the pin and go to manual configuration (since I have a domain name). We enter the correct information for host (https://domain.com & 8920 since I use SSL) and when selecting "OK" end up getting bumped back to the Emby start page, asking for the account pin... and none of the server settings are retained... never even attempts to reach out to the server. Thoughts?
Luke 42246 Posted February 2, 2019 Posted February 2, 2019 Hi there, what kind of SSL cert are you using?
Tiberius76 0 Posted February 2, 2019 Author Posted February 2, 2019 OpenSSL-W32 Works on all other devices, and is configured correctly... no issues with Roku, Xbox 1, web or android apps.
ebr 16338 Posted February 2, 2019 Posted February 2, 2019 Hi. How do you know it never attempts to connect? Can you tell us exactly how you are entering the address and port and which buttons you press? Thanks.
Tiberius76 0 Posted February 3, 2019 Author Posted February 3, 2019 No Amazon Fire device shows as ever connecting in the Device section of the admin panel Address is being put in as https://domain.com and port changed to 8920 After entering server info, next or ok is the only option (not at it right now) and selecting that sends you back to the Emby connect sign in... And when you go back to manual settings all the server and port info is gone.
Luke 42246 Posted February 3, 2019 Posted February 3, 2019 Well that is a connection failure, although the app should handle it better and present you with a graceful error message. Can you find out if Amazon devices will trust your certificate? The fire tv app is not doing anything to override this, so if the device does not trust the certificate, then it will reject it and it won't be able to connect.
ebr 16338 Posted February 3, 2019 Posted February 3, 2019 and selecting that sends you back to the Emby connect sign in... How long is it between you pressing ok and you arriving back at the other screen?
Tiberius76 0 Posted February 3, 2019 Author Posted February 3, 2019 The return to the home screen is almost immediate... almost as though the app is registering the "OK" as a "BACK" instead
ebr 16338 Posted February 3, 2019 Posted February 3, 2019 The return to the home screen is almost immediate... almost as though the app is registering the "OK" as a "BACK" instead Yeah, I think this is a problem with the dialog interface which is quite wonky in some versions of Android. Once the port is entered with the OSK, try just arrowing up to the dialog, then focus the OK button on the dialog (not on the on screen keyboard) and press that...
Tiberius76 0 Posted February 3, 2019 Author Posted February 3, 2019 I'll try that and update (not at the Fire Stick now)
